New build - Car Audio Classifieds!
Old 01-09-2013, 02:58 PM
0/11 ssssssss9
Default New build
I want to do a temporary build with 2 obsidian 15s and Here is what i was thinking. Crescendo bc2000d to power the 15s, I want to do a ported box tuned to 25hz for them Lows out of 3/4 birch this will be after i do my Big 3 upgrade shortly. I dont think i will need another battery or alternator for this build but i could be wrong. And if anyone has some box specs i could use that would be cool. any suggestions also are appreciated.
Old 01-09-2013, 03:01 PM
0/11 ssssss776
What ohm will the amp be ran at? Id do 3-3.25 per sub or so.
1993 Jeep Cherokee 4 Sundown ZV3 15s, 2 Sundown NS-1s, 4th order BP, 12 XS Power d1600s
3 Mechman 300 amp alts
2011 NC Middleweight champion
2011 Middleweight World Champion
2012 Middleweight World Champion
157+ 3 round music avg
Old 01-09-2013, 03:02 PM
0/11 ssssssss9
1ohm
Old 01-09-2013, 07:29 PM
0/11 sssssss32
I'm doing a single OA15 build. I've plotted everything from 3-3.5 cu. ft and tuned 30-35 HZ. Between 3 and 3.3 and 30-33hz, the F3 only changes 1HZ (26-27 HZ). Anywhere in that range should yield a very nice result.
Old 01-09-2013, 08:59 PM
0/11 ssssssss9
I was thinking of going 4.4cubes at 25hz. Thats a little under recommended but i heard if i wanted to overpower them i should go a little under recommended cubes but idk they would prob be fine on 5-6 cubes. I want to put anywhere from 800-1000rms on them for daily bumping
Old 01-09-2013, 09:17 PM
0/11 ssssss776
Stick with atleast 3 cubes per sub. Even with 800-1000 watts.
Old 01-09-2013, 10:17 PM
0/11 ssssssss9
i mean 800-1000 to each sub
CLNFREAK'S build... rebuild.... build... CLNFREAK Build Logs 43 06-26-2012 06:25 PM
2 18" Fourth Order build this weekend-Tips before build sxpimpin Enclosure Discussion & Design Construction Help 10 03-15-2012 08:13 PM
temporary budget build...94 xcab ranger (work truck build) CodyBrown2013 General Car Audio Discussion & Questions 8 02-17-2012 09:44 PM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
