Am i Screwed?? - Car Audio Classifieds!
Old 01-09-2013, 07:40 PM
0/11 sssssss65
Default Am i Screwed??
so after tearing apart my car to apply alpha damp and run my amp 4gauge power wire through my firewall. i started thinking about how i was gonna run rcas and speaker wire, i looked at the accordion grommets on my drivers side and passenger side and figured id run through there......decided to take off the speaker grill and look at the connection. my car has the speaker wires soldered to the speaker....then to an adapter.....THEN it runs through the door and up into the dash
Problem the drivers side accordion looks to be unaccessable because its blocked by my emergency brake system,
theory- do i try and find where those speaker cables run into my head unit....and cut them before they run into the headunit and route them to my amp essentially creating the chain
headunit--->eq-----> amp speaker wire----> old(existing) speaker connections---->speaker
what are my options?
Old 01-09-2013, 07:46 PM
Rocken JBL's Avatar
0/11 ssssss941
Feedback Score: 21 reviews
yes that is exactly what you do... essentialy "piggy backing" your wires
Owner-The Dog Pound Car Audio Club, Owensboro
-Team Sundown Audio
-FCBC 200 MOD Champion 2012
-Runner up 200 SD Champion 2011/2010
-MECA AS2 Kentucky state points Champ in 2010
The Following User Says Thank You to Rocken JBL For This Useful Post:
R1C0rtez (01-09-2013)
Old 01-09-2013, 07:50 PM
0/11 sssssss32
Maybe make a small hole from the outside of your factory wire grommet into the cabin of your car. Then run a screwdriver into the hole and into the cabin. Feel around and see if you can find it. Sometime they are reachable, but not visible.
The Following User Says Thank You to big_jwee For This Useful Post:
Old 01-09-2013, 07:52 PM
1/11 ssss31258
pull the accordion boot grommet from the body side and then feed the speakerwire in the hole toward the inside of the car. routing will take a smooth technique to get it in where you can feed it and reach it from the inside. {a wire hanger can help}
then feed the wire in the accordion boot to the door. and reinstall the boot grommet
Rocken JBL's Avatar
0/11 ssssss941
that will work too, however doing what you are talking about will be alot easier i would say
-Team Sundown Audio
Old 01-09-2013, 08:06 PM
0/11 sssssss65
thanks for the quick replies! yea i went and pulled my grommet real quick and it came out pretty easily ill snake something in there when i have the chance it was too narrow of a space for me to see where it was going and ill see how that plays out,....if not ill look up my pinouts online and route from there.....thanks everyone!
Old 01-10-2013, 04:01 AM
0/11 sssss5305
you can also remove the parking brake, usually only 3 nuts/bolts holding it on
I keep getting screwed. 3rdshiftdiscretion General Car Audio Discussion & Questions 31 02-23-2012 05:07 PM
I think i just got screwed by caraudionewbie9 Beatdown337 Off Topic Chat 96 04-22-2010 07:23 PM
Im screwed DLP customs Off Topic Chat 31 12-13-2008 02:00 PM
