Which sub would be best for my application?? SA or AB - Car Audio Classifieds!
Old 01-10-2013, 06:46 AM
0/11 sssssss87
Default Which sub would be best for my application?? SA or AB
I was dead set on going with 2 sa15's but I can get AB XFL 15's at a damn good price. I will be running an aq2200 amp. I got about 7cu ft of air space to work with and 2 6" aero ports. It will be tuned to around 35 or 36 hz. Going in a boat. So open enviorment kinda hard to hit anything below 32hz or so. So which sub would be best for what I have to work with. This is music only of course.
Old 01-10-2013, 06:52 AM
Prohibited Sellers/Buyers
0/11 sssss1590
This one is a tough call. Im a sundown nut hugger so i'd say sundown but the ab's are good too.
As far as output goes i think the sa's would sound better on that power. But the ab's would run a lot cooler.
In my familys boat were running 2 zv3 12s in 6.1cubes tuned to 33hz on an saz3500 and it sounds great.
I think it comes down a little bit more to personal preference.
Old 01-10-2013, 07:11 AM
murderedtahoe's Avatar
Mr. Low End Monster
0/11 sssss3512
op I have used both subs, if you can get the AB woofer cheaper this is a no brainer
Old 01-10-2013, 08:21 AM
HACKMUNCH's Avatar
0/11 sssss3892
I have used both also, both good. Is 1 better than the other
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 01-10-2013, 08:54 AM
0/11 ssssss145
I agree, it comes down to personal preference. However, for a boat set up I'd do the cheaper route.
Old 01-10-2013, 09:57 AM
0/11 ssssss464
those sundowns will come alive on that 2200 however the ab will want more power to really perform so unless u wanna add another 2200 down the road the sundowns may be better NOW but the AB will be much better with more power
Old 01-10-2013, 10:22 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
go with whatever is the cheaper sub. both are good so it is a win/win either way.
My game is legit,
Old 01-10-2013, 10:24 AM
Mr.G6's Avatar
0/11 sssss4614
frankly a aq2200 is not enough power for a pair of xfls.. the sa's will be more efficient on that power
xfls LAUGH at 1000w a pop
edit.. omg another boat system
2000 Gmc Sonoma ext cab
Best 12's for my application? ChromeJerome General Car Audio Discussion & Questions 26 12-03-2012 10:49 AM
What's the best sub for this specific application?? newarkbeast973 (Sundown Audio) 13 11-15-2011 06:52 PM
best subs for my application? 20Hz_And_Below General Car Audio Discussion & Questions 2 02-22-2011 12:35 PM
Filed my application dropped_tb Team CACO 16 10-08-2009 04:53 PM
