removable port - Car Audio Classifieds!
Old 01-10-2013, 07:48 AM
0/11 sssss1513
Feedback Score: 17 reviews
Default removable port
Gonna be building a box for a xfl 15, thinking about 3 cubes with a removable port so I can play with tuning. Not gonna order an aero I like building with wood. I've done and octo pretty easy , I m assuming I can do this with a regular slot port. Is there a difference between square or rectangular, I'm sure there isn't just looking for recommendations
Old 01-10-2013, 08:32 AM
0/11 sssss1513
anybody?
Old 01-10-2013, 09:28 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Disregard this post... Tapatalk wont let me delete it
\/ below is my post... Sorry
Sent from my MB870 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 01-10-2013, 09:31 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Port area is port area, be it square or rectangular or a circle, one may be louder but yes an interchangeable port will work regardless shape. I'm assuming you meant interchangeable, cause if you just take a port out you have a hole tuned to 270hz lol. And if you want play with tuning on a slot build your port big to begin with say and just build plugs that will slide and screw/bolt in.
TEAM DURTY POWA!!!
Old 01-10-2013, 09:37 AM
0/11 sssss1513
I wasnt thinking about port area as much as tuning length, I ll get an idea of port area think 16 per cubic foot, Then If the port is removable then I can just cut shorter and shorter to get to the desired tuning.
Old 01-10-2013, 09:39 AM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
Sono tubes ftw!
Just do it.
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 01-10-2013, 09:46 AM
0/11 sssss1513
I do have some 6" carboard tubing, at home very thick cardboard. was worried about port noise.
Old 01-10-2013, 11:04 AM
0/11 sssss1513
how much port area should i shoot for for an xfl 15
Old 01-10-2013, 11:27 AM
vince79vette's Avatar
0/11 sssss2011
I use sonic tubes from lowes. Very easy to use and cheap and u can cut one hole and tac the tube in and caulk around it and if u need it longer or shorter u can cut the caulk and pop the tacks out and slip in a new piece. And from what i have done with my box in removable port the sonic tubes sound better then a big square port
Sent from Chuck Norris foot
Old 01-10-2013, 05:43 PM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Pull the wax backing off the tubes, coat with resin and sand.
Team XS Power
Team Heavy Hertz
Build-
youtube-
removable port help aqspud15 Enclosure Discussion & Design Construction Help 6 03-28-2012 04:53 PM
Removable port disatvantige? Russellabt General Car Audio Discussion & Questions 2 03-21-2011 02:17 PM
new box with removable port burzendowski Build Logs 7 07-30-2010 03:15 PM
removable battery, best way to do it? Anton Miller General Car Audio Discussion & Questions 1 04-28-2010 09:45 PM
Removable Ports? dak446 General Car Audio Discussion & Questions 19 09-24-2009 04:21 PM
