Wiring dvc and svc subs together? - Car Audio Classifieds!
Old 01-10-2013, 11:14 AM
vince79vette's Avatar
0/11 sssss2011
Default Wiring dvc and svc subs together?
I have 2 mtx 9500 one duel 4 and the other single 4 can i hook them up togther and will they both get the same power or will the dvc use more
Sent from Chuck Norris foot
Old 01-10-2013, 11:25 AM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Dvc will use more. Dont do it.
Sent from my PG86100 using Tapatalk 2
Old 01-10-2013, 11:31 AM
0/11 sssss2011
Had a feeling of that. Thanks
Old 01-10-2013, 02:23 PM
0/11 ssssss464
not only would it use more but they couldnt be in a common airspace IIRC
Old 01-10-2013, 02:32 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
just hook up the single vc and only 1 of the dual vc so the amp will see 2 ohms. it may be ghetto but should work. i have seen alot of people do that.
My game is legit,
Old 01-10-2013, 02:35 PM
btsteinb's Avatar
0/11 sssss3573
Didnt think of that. Try it. Whats the worst that can happen. Are they the same version of the 9500? Just start at low volume, and slowly turn it up.
Old 01-10-2013, 02:42 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
you are lucky that you have not seen some of the "rigged up" shit i have seen.
My game is legit,
Old 01-10-2013, 02:45 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Not really a good idea to just run 1 coil from the dvc sub alone....I thought both had to be hooked up together to prevent damage to the speaker. I wouldn't suggest running a dvc and svc subs together. Either get rid of the other or just run 1 by itself.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-10-2013, 02:49 PM
btsteinb's Avatar
0/11 sssss3573
Worse i see is the power wire running out of the hood and into the door jam outside of the car. So outside the a pillar.
I ran a image dynamics on a singe coil for about a month in my ht before i reconed it. Idk about multiple subs. The dvc might have more mass, and lower the fs and mess uo the setup. Make the box a dual chamber and do it. Only way to really know is try.
Old 01-10-2013, 03:06 PM
0/11 sssss2011
I am pretty sure i can find some shit dvc and svc and do some test an see. I have always thought u needed both coil hooked up. We will see
Wiring Two DVC 4 ohm Subs andes11 General Car Audio Discussion & Questions 29 09-04-2010 09:47 PM
Dvc sub wiring question? YOUNGGUNA General Car Audio Discussion & Questions 4 03-08-2010 01:38 AM
[SOLD] 5 ED 8" subs 4 svc 4 ohm 1 svc 2 ohm on1wheel01 Car Audio Trader (WTT) 8 02-23-2010 07:12 PM
[BASIC] What Should I Get? SVC or DVC? danteBirosel Tutorials & Quick References 0 11-12-2008 02:11 PM
[BASIC] Wiring Diagrams: Single Voice Coil (SVC) danteBirosel Tutorials & Quick References 0 11-12-2008 02:07 PM
