anyone know the BL of atomic apx818? - Car Audio Classifieds!
Old 01-10-2013, 12:44 PM
beatnbronco's Avatar
0/11 sssss2284
Default anyone know the BL of atomic apx818?
I'm working on another build and i would really appreciate a little help with a few questions..here goes..
I need a motor comparison..first motor is the RF T2
BL is 21, uses a 4" coil, has triple 1" ferrite slugs at 8.25" OD, 1/2" top plate and bottom plate..and the motor is noticably heavier than the atomic
2nd motor is Atomic APX818, not sure what the BL is..does anyone know??
the motor uses a 4 layer 3" coil, has dual 1" ferrite slugs with close to if not the same OD, 1" top plate and 1/2" bottom plate
questions are:
does anyone know the BL of the atomic?
which motor is stronger?
are higher BL's stronger?
if i was to build 2 subs, 1 with a motor with a BL of 21 and the other sub with a motor with a BL of 29, would the rms/max be different? what affects does the BL of a motor have on the performance of a sub?
thanks for any help provided, i hope to get these questions solved before saturday morning cuz that's when motors ship to me...let er rip!!
Old 01-10-2013, 05:44 PM
0/11 sssss2284
can anyone help?
Old 01-10-2013, 05:56 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
BL is dependent on re.
a sub wire to 1 ohm and ts pulled has bl of 9
same sub wired to 4ohm and ts pulled has bl of 18
some good info in this thread that should answer most of your questions.
Scientifically what are the Top 5 strongest motors out?
Old 01-10-2013, 06:04 PM
BKNIGHTS's Avatar
0/11 sssss2949
Strong BL is great for a spl woofer.
Too strong of a BL will affect the frequency response curve making a certain bandwidth louder then the rest. You dont want +2db a 50hz and the rest of frequencies lacking.
Old 01-10-2013, 06:09 PM
BKNIGHTS's Avatar
0/11 sssss2949
more info in this thread as well
Motor force fi sp4
Old 01-10-2013, 06:11 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
The APX 818 is alot stronger! The T2 motor is actually kinda weak, atleast in comparison. Also, Idk if you have a true apx motor since my 818 is 40lbs or more and 9" in diamater.
Bl dosn't indicate motor strength in comparison...Some beefy subs don't have a such a high bl. Go by bl^2 / RE
Old 01-10-2013, 06:17 PM
0/11 sssss2284
i had to guess at the diameter of my motor beings they're mounted in a box right now..i was having so much trouble finding 2 more 818's to make the jump to 4-18's so i thought of switching motors..guess i'll be sticking with the atomics then....problem solved
Old 01-10-2013, 06:20 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
bl will change with how full the gap is of coil also
its not a parameter you can guess only measure it
Old 01-10-2013, 07:37 PM
0/11 sssss2284
didn't guess at anything but the motor diameter of my 818's..i'm sticking with the atomics till i can find 4 of the same motors..i'll just use the T2's to build my brother a pair of subs
apx818 daily q Brianyakno General Car Audio Discussion & Questions 3 02-03-2012 12:07 AM
atomic apx 856 recone - atomic vs rd audio rachidfunaki General Car Audio Discussion & Questions 7 04-14-2011 03:16 AM
atomic 7k fox_racin4 General Car Audio Discussion & Questions 19 09-18-2010 10:26 AM
[NLFT] blown rd 7500.1 for atomic apxx? or atomic 3k amp? Violence* Car Audio Trader (WTT) 36 04-28-2010 06:46 PM
