Wiring 3 batteries and 2 amps? - Car Audio Classifieds!
Old 01-12-2013, 05:16 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Default Wiring 3 batteries and 2 amps?
Okay, I was just wondering..my last setup I had the ground go from my D3100 batt to the frame and the ground from the amp going to the ground on the battery. Everything worked fine. I didn't see much voltage drop...but since I'm going for SQ, I want to make sure I do everything right. AS much as I want to eliminate drilling holes into my car...is this the best way to wire all of these:
Picture contains 2 back up batteries 1 starter battery, 2 amps and a processor.
Please correct me if I'm wrong or tell me some other ways I can wire this to eliminate putting more holes into the frame of my car.
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 01-12-2013, 05:36 AM
Mr.G6's Avatar
0/11 sssss4614
wiring it a differnt way its going to get you more "sq"
that comes from the equipment only lol
edit..ground the batteries to a solid point and run the amp grounds off the battery
2000 Gmc Sonoma ext cab
Old 01-12-2013, 05:41 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
meh, shut up lol. I like to act stupid sometimes
Thanks for the feedback though.
yeeeahhh.
Old 01-12-2013, 05:44 AM
Mr.G6's Avatar
0/11 sssss4614
its ok im just being honest..
ever think of using the strut towers in the back? if they are accesable
Old 01-12-2013, 05:55 AM
Mr.G6's Avatar
0/11 sssss4614
bc the car is a uni body and the strut tower is a formed solid piece of the car itsself
Old 01-12-2013, 06:07 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Very good idea sir.
yeeeahhh.
Old 01-12-2013, 06:28 AM
Mr.G6's Avatar
0/11 sssss4614
Very good idea sir.
the only other really solid peice of metal on the car is the rear crash bar
( the metal support inbetween the bumper ) its bolted to the car also
i have 1 0g run to each strut tower and 2 holes punched in the spair tirewell with 0g running to that bar where i have drilled holes and used stainless bolts n washers and painted over with undercoating
i always paint over the grounds as soon as im done
Old 01-12-2013, 08:10 AM
newarkbeast973's Avatar
0/11 sssss7810
Why not just 1 run of pos and 1 run of neg from front to back?
New build coming soon!!
Old 01-12-2013, 08:35 AM
99Bonney's Avatar
0/11 sssss6246
X2, then just wire up the amps to the closest battery.
Old 01-12-2013, 10:56 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Battery is in the trunk (at least on the 10 Challenger). Gotta love Dodge. They have a factory 1ga-ish positive ran already.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Wiring batteries in series vs. parallel. LEN671 General Car Audio Discussion & Questions 23 10-10-2012 02:08 AM
Wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 11 09-09-2011 12:12 AM
WTB: sa-10s, wiring, terminals, batteries, etc. cynicz Wanting to Buy (WTB) 1 06-22-2011 03:41 AM
wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 2 06-16-2011 11:57 AM
