Big Trunk Car.... Should I Downfire????? - Car Audio Classifieds!
Old 01-12-2013, 11:45 AM
0/11 sssss1181
Default Big Trunk Car.... Should I Downfire?????
I have a 93 Caprice and 2 new dc xl 15's. I've designed a box pretty close to dc spec with the woofers firing up and port to the side. My question is would it be better to build a box to the same specs but downfiring it against the floor instead of the well deadened trunk lid?
Old 01-12-2013, 11:58 AM
Yeah, its me!
0/11 sssss1184
Feedback Score: 41 reviews
I personally wouldnt downfire, id point it towards the rear of the trunk. With any luck you would be able to rotate the box to several different configurations to see what sounds the best.
Old 01-12-2013, 12:00 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would do all rear firing if you can.
Old 01-12-2013, 12:26 PM
0/11 sssss1181
unfortunatley building the box and trying other configurations and angles is not possible in this build. I have to do it and get it right the first time but thanks. any other input?
Old 01-12-2013, 01:28 PM
SWIFT's Avatar
0/11 ssssss656
One of my best sounding setups was downfiring in a trunk. I had two 15's downfiring into the spare tire well. The box was raised about 2 inches from the trunk floor and the opening to the spare tire well allowed for good cabin gain, there was probably a 10in deep well they fired into. If you dont have a deep spare tire well then I wouldnt do it.
Down fire and port to the rear would sound great if done properly.
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 01-12-2013, 01:30 PM
DLP customs
Guest
0/0 sssssssss
Fire toward the trunk. Always the best meter wise.
Old 01-12-2013, 01:51 PM
doug118's Avatar
0/11 sssss4674
No it's not. Another internet rumor. Fire forward into the back of the back seat will be louder than firing towards the trunk? Not all cars have folding rear seats and some have huge bracing behind them too
The Following User Says Thank You to doug118 For This Useful Post:
dcollister440 (01-15-2013)
Old 01-12-2013, 01:53 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I've done several caprices, in this case it is louder
Old 01-12-2013, 01:55 PM
DLP customs
Guest
0/0 sssssssss
That is not a internet rumor. I ran many trunk cars and without firing through the back seats with a port. Rear firing is the way to go.
meter at 30hz, the rear fire will crush the forward setup sealed legal.
Downfire or not? LyferXB9s General Car Audio Discussion & Questions 4 04-18-2011 04:17 AM
Got me a new car with a BIG trunk! Oldbass38 Off Topic Chat 14 10-21-2010 07:13 PM
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 08:24 PM
downfire ported boxes?? KRestevan Enclosure Discussion & Design Construction Help 0 03-20-2010 11:32 PM
Wanted : Tutorial on doing Big Three when battery is in trunk NOFATTYS Tutorials & Quick References 2 04-17-2009 09:17 AM
