Which AT speaker wire is best for this setup - Car Audio Classifieds!
Old 01-12-2013, 12:07 PM
arejayeye's Avatar
0/11 ssssss317
Default Which AT speaker wire is best for this setup
100ft of Audio Technix OFC 8ga is $149.99 - 735 strands / 6.5mm
100ft of Audio Technix OFC 10ga is $85.99 - 462 strands / 5.5mm
Which would you go with for 4 xfl 15s on 4.5K. I just don't think the price difference of the 8ga is worth it. Thoughts?
Old 01-12-2013, 12:14 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
If you plan on running each sub into a set of terminals, do the 8 gauge, if you plan on wiring all together, then use the 10, but you'll be trimming wire, i would use 10 and run each to a set of terminals, 8 gauge is really over kill unless you were running the 4.5k to say 2-15"s
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 01-12-2013, 12:15 PM
0/11 sssss1381
10g is fine u cant fit two 8g in a terminal of those subs
2014 Chevy Silverado lifted 9 inches
Fuel 24x12s and 35s
Nations dual alternator bracket dc power 370 alt, 3 Fi SP4v2 18s,big ass 16v stable amp , JY 45ah 16v Lithium, JY ofc 1/0, fiberglass doors, 3 krome ka10s 3 mclaren mlt8 tweeters. 2 soundigital sd2000.1 evos on mids mclaren 600.2 on tweeters. Pioneer 80prs
Old 01-12-2013, 12:31 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
why the eff are you ordering 100' should be the real question here.lol. When i just completely rewired my box i used MAYBE 25' of length.
-Youtube Channel
Old 01-12-2013, 12:36 PM
arejayeye's Avatar
0/11 ssssss317
It's cheaper ordering 100ft. I figure I will use it eventually anyway
massivespl's Avatar
0/11 sssss8409
i used 25ft to wire up my 4 18's so if u order 100ft thats alittle over kill and your going to have 75ft left over. but i'd get the 10gauge and save some money. 10gauge will work fine
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-12-2013, 01:03 PM
Mr.G6's Avatar
0/11 sssss4614
i do a run per coil
that way if i drop a coil etc its easier to track down
i used 20ft on just a single woofer
2000 Gmc Sonoma ext cab
Old 01-12-2013, 02:02 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
well that sucks.lol
-Youtube Channel
Old 01-12-2013, 02:08 PM
Mr.G6's Avatar
0/11 sssss4614
well that sucks.lol
i just buy the cheap q power ofc 8g wire
its super cheap lol and works great decent ofc wire
1/0 wire, 4awg wire, fuse holders, speaker wire, baffles, RCA...lots! dacheatham Wiring, Electrical & Other Installation Equipment 4 08-30-2012 06:16 AM
misc wire 12 ga and 8ga speaker wire, speaker rings, bass knob financethis Wiring, Electrical & Other Installation Equipment 1 04-08-2012 11:23 PM
wire wire wire 2/0 1/0 4ga & speaker wire dgaf_ Wiring, Electrical & Other Installation Equipment 11 04-08-2012 08:06 AM
FS: 16 gauge speaker wire, speaker terminals, MDF speaker rings YouSirName Wiring, Electrical & Other Installation Equipment 13 02-12-2012 04:04 PM
FS: 14 gauge speaker wire, speaker terminals, MDF speaker rings YouSirName Wiring, Electrical & Other Installation Equipment 2 01-15-2012 11:36 PM
