RCA voltage too high for amp? - Car Audio Classifieds!
Old 01-12-2013, 03:16 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Default RCA voltage too high for amp?
So I'm out here an just installed a new clarion eqs for use with my 4 channel. My issue is, when hooked up, I have horrible ground noise and static. I did not have any at all with rcas direct to the HU though (4v Pioneer) I've tried both old and brand new rcas from the HU to eq and still have the horrible noise. It even goes as far as not hearing anything until almost max volume, even then it's horrible and crackles like all hell. Even tried grounding the RCAS, and nothing.So I'm thinking since my amp is pretty old (alpine v12 f303 iirc) that it doesn't like the higher RCA input voltage. Any thoughts
Sent from Uranus
Old 01-12-2013, 03:20 PM
DLP customs
Guest
0/0 sssssssss
does the amp have a good ground?
Old 01-12-2013, 03:24 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
As mentioned, I have zero issues from HU direct to amp. It's only when RCAs are to eq. But to answer your question, yes. It's ground is going to my rear battery bank.
Sent from Uranus
Old 01-12-2013, 04:00 PM
badmofo529's Avatar
0/11 sssss3329
Sent from Uranus
Is the bank grounded good? I'm getting a shitload of whine through mine because my ground for my batt bank is shit. Had no issues without batts in the rear.
Sent from my HTC Inspire 4G using Tapatalk 2
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 01-12-2013, 04:25 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
It should be. I'll look for a new one tomorrow.
Old 01-12-2013, 04:33 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
What's pre out voltage on the Clarion?
Old 01-12-2013, 08:07 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
7v. At least that's what the description says.
Old 01-13-2013, 02:01 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Ground is good. Any other thoughts?
Old 01-13-2013, 02:27 PM
Biggcaddi's Avatar
0/11 sssssss59
Are your rcas directional ? I had that problem once with an old memphis parametric i installed and come to find out my the signal was travelling the wrong way in the rcas. Yep it made me feel a lil dumb. lol
Old 01-13-2013, 02:38 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Tried both ways.
Taramp's high-voltage 50kw amp?? Wingman0121 General Car Audio Discussion & Questions 40 06-28-2013 10:53 AM
low voltage on h.u. rca / setting amp gains caloriu General Car Audio Discussion & Questions 8 02-03-2012 11:44 PM
RCA Voltage? GoodyearJason General Car Audio Discussion & Questions 4 07-06-2011 10:23 AM
Headunit RCA voltage linearity SpeedEuphoria General Car Audio Discussion & Questions 11 05-25-2011 09:52 AM
RCA voltage boosting jt_buck General Car Audio Discussion & Questions 27 04-20-2011 05:33 PM
