ground wire questions - Car Audio Classifieds!
Old 01-12-2013, 08:20 PM
califaplayer707's Avatar
0/11 ssssss237
Default ground wire questions
I have a yellow top optima battery in the front and im adding an xs power d3100 in the back,
my question would be would it be better to ground the xs power battery using an 18 inch long power wire to the frame or can i do something a little bit longer maybe 2 feet?
also i need to ground my amp but i would need to use a 2 feet long ground wire i was told its better to use a short ground wire and that it would be better to just ground it to the xs power battery, is that true can i do that without causing a short/fire?
Old 01-12-2013, 08:33 PM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
You can use the 2ft from the rear batt to the frame then ground your amp to the battery negative. But if you don't need it to be 2ft, go with the shortest lenght needed.
Old 01-12-2013, 08:39 PM
0/11 ssssss237
So its okay to ground my amp to the battery?
Old 01-12-2013, 09:01 PM
0/11 ssssss577
yes its never a bad idea , and your fine with 2 ft runs
The Following User Says Thank You to harrisondesigns For This Useful Post:
califaplayer707 (01-12-2013)
Old 01-12-2013, 09:05 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
thats what you're doing if you ground it to the frame anyway
-Youtube Channel
Old 01-12-2013, 09:23 PM
0/11 ssssss237
Sounds good then Thanks everyone for the help i appreciate it
ground wire hdman87 General Car Audio Discussion & Questions 50 01-04-2011 04:41 PM
Running power wire and ground wire Audio_Prodigy General Car Audio Discussion & Questions 2 09-14-2010 12:03 PM
Ground wire Bigbodylexus General Car Audio Discussion & Questions 0 09-12-2010 05:10 PM
[SOLD] Misc kicker, fuse holder, RCAs, ground wire, remote wire and more lil_italy773 Wiring, Electrical & Other Installation Equipment 2 01-28-2010 08:58 PM
power and ground wire Fosgate1 General Car Audio Discussion & Questions 15 06-25-2009 05:16 AM
