how do the legs of a circuit affect power seen? - Car Audio Classifieds!
Old 01-13-2013, 01:34 AM
0/11 ssssss318
Default how do the legs of a circuit affect power seen?
so this is my question i was reading my auto book and i got the understanding that in parallel all legs given the same resistance will see the same power. is this correct? also series how does that work out. i had 2 fullrange speakers in my dash both 2 ohms wired in series with a 4 ohm coax this created an 8 ohm load which i paralleled with a 4 ohm load to get 2.6. my question for future wiring issues and install how does this all work out?
SIDENOTE: i have a sa-12d4 in 2.9cubes on a brz1700 at 2 ohms i dd-1'd it the other day and got a clean rail voltage at 14.2vdc of 48.8VAC which on a purely resistive load of 2 ohms would be 1190ish watts of power. IT DOES RATED. the 1700 is rated at 1700(duh) at 1 ohm which would be 41.2VAC. ive noticed not all amps assume a constant efficiency where the power doubles every time you halve the load. so would this be a flaw in the dd-1 because when this d4 dies i plan on getting a d2 recone. and if i dd-1'd out to 48.8 id be making 2380W which would surely be clipping. ive read up quite a bit about the dd-1 and IVE NEVER SEEN ANYONE BRING THIS UP. does this question hold any validity?
Old 01-13-2013, 02:11 AM
0/11 ssss31258
addressing only your subwoofer setup and thinking around it;
you are assuming too much.
#1 at your output voltage peak, the 2ohm load is not a 2 ohm load. {it's higher}
#2 you can not assume your amplifier's output into a load you don't have.
the dd-1 only sets your input gains based on the best possible scenario. it does not adjust for voltage drop, THD or damping factor changes with different impedance.
honestly, a DD-1 is "good enough" compared to no gain setting utensil at all.
but,
even after you set your gains with the DD-1, you have to be smart enough to know when you need to turn a gain down. sometimes, set 'perfectly' leaves you with a system which does not have 'control' of itself.
Old 01-13-2013, 02:33 AM
0/11 ssssss318
i know i have rise and i watch my drop. i wanna say i still had rail voltage for over 1100W with the car off. im just saying some people make the dd-1 seem so glorious and it is pretty cool and has its place.
lets say i had the ultimate 100% efficient box with no rise id eventually kill the amp if i dd-1'd instead of dmm'd. id just thought id make a point and hopefully someone will come in and answer my circuitry questions.
maybe ill be able to clamp my amp tomorrow and see what my rise actually is. and i know its not just hifonics that doesnt double there power every time the load is halved.
so you have clean rail voltage for your 4 ohm output but that rail voltage may be too much over the 2 ohm rating. like with my dash its running off an old alpine 3522s rated at 12v at 30w into 4 and 45 into 2 both x2. im running it at 2 ohms so i dd1'd it lets say i set it to clean 4 ohm rail voltage what then? i know they probably rise a little from inductance but id be my active load stays under 3 ohms.
though the old fosgate p201s i put in last night and set by ear does double its power. i know power also depends on the amps ability to fight the back voltage produced by the sub/speaker. if i understand it correctly the coil moving through the magnetic field acts somewhat like an alternator or brushed dc motor and produces its own amount of voltage I THINK.
Tantric MD 12" stretching its legs Skip01 Car Audio Videos 26 11-04-2012 05:43 PM
Will this affect my sub's performance? DevinG17 General Car Audio Discussion & Questions 8 11-18-2011 12:27 AM
Affect tuning at all? csu87 General Car Audio Discussion & Questions 7 10-21-2010 02:19 AM
2V preamp vs 4 or 5V...affect on sound? SVTFOOCUS General Car Audio Discussion & Questions 21 11-05-2009 02:49 PM
