Aq2200 plays soft then loud then soft - Car Audio Classifieds!
Old 01-13-2013, 08:15 AM
vince79vette's Avatar
0/11 sssss2011
Default Aq2200 plays soft then loud then soft
I picked up a aq2200 for cheap and saw when i was playing it. It would play loud then soft like if i turned it down then back loud again. It dose it random too. I did check to see if it was the song and it wasnt
Sent from Chuck Norris foot
Old 01-13-2013, 08:28 AM
wccfan's Avatar
0/11 ssssss114
I don't know if this helps or not but check you fuse on the power wire. This is the main reason I switched from AGU fuses to ANL fuses because my old hifonics amp used to do this. Switched the fuse out and it worked perfect. Try replacing the fuse on the power wire and see if this helps any. If possible I would check the voltage at the amp, and at the part of the wire before and after the fuse. Hope this helps.
Old 01-13-2013, 08:38 AM
4/11 ssss31258
I've had tinsel leads break on paralleled DVC subs and when it made connection it was like a turbo boost... the sound would get loud for a second.
it also usually killed my amp.
otherwise..
I've seen bad power supply capacitors cause fluctuations also.
I've seen loose output resistors cause on/off fluctuations also.
Old 01-13-2013, 08:44 AM
0/11 sssss2011
otherwise..
The subs are sa 10s if that matters to but u think in might be something in the amp. The amp has never turned off just acts like if i was playing with the vol knob alittle. Maybe i will have to look inside it tonight
Old 01-13-2013, 08:45 AM
0/11 sssss2011
I will have to check that out to
Old 01-13-2013, 10:18 AM
0/11 sssss2429
Feedback Score: 46 reviews
Sounds like you have a intermittent rca connection.
Only hook up one at a time.
The Following User Says Thank You to brandes.cm For This Useful Post:
timwebb (01-13-2013)
Old 01-13-2013, 10:54 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
what ohm load is the amp wired to?
My game is legit,
Old 01-13-2013, 10:57 AM
0/11 sssss2011
I think the subs are wired to 2. Its was in my buddys car i will have to double check and i will try the rca thing too
Old 01-13-2013, 11:09 AM
duff_thrust's Avatar
0/11 ssssss629
if it's the black in the center and silver on the outside RCA connections then I'm nearly positive you have a RCA solder joint that is broken, it probably makes connection then loses it at random so you're seeing say 4 volts, then 2 volts then back and forth. Depending on your headunit. Had this happen on an amp of mine, that amp was an AQ 2200. It had the old style RCA inputs like I described.
Old 01-13-2013, 11:13 AM
Wingman0121's Avatar
0/11 sssss2171
Had the same issue on one of my amps before, turns out it was corroded gain/crossover controls and the sound will go from soft to loud to soft when I go over bumps. Sprayed some deox-it into the potentiometer and everything was fine.
Air Soft TeamTRUsound Off Topic Chat 5 12-06-2011 06:35 PM
soft parts timwebb General Car Audio Discussion & Questions 1 12-01-2011 12:00 PM
Soft Parts marcmdm2005 (Fix My Speaker) 7 06-09-2010 10:46 AM
Soft Parts - Who has them? bwoodroof General Car Audio Discussion & Questions 1 02-24-2010 02:40 PM
Is there any way to tell what soft parts on a sub? westman995 General Car Audio Discussion & Questions 6 07-31-2009 11:55 AM
