Fi BL max Xmax - Car Audio Classifieds!
Old 01-13-2013, 04:54 PM
0/11 sssss1691
Default Fi BL max Xmax
Both ways of course the site says 18mm but what's the max throw it has both ways any info would help am if anyone has a good video of the sub flexing would b ideal
1996 Chevrolet Impala SS
sub stage : 2 12 orion hcca d2
mids and highs stage: nothing yet
Amps:
bass amp: nothing yet
Mids and highs amp :Audison sr5 for now more to come
Old 01-13-2013, 04:55 PM
massivespl's Avatar
0/11 sssss8409
36mm ?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-13-2013, 04:59 PM
0/11 sssss1691
Originally Posted by massivespl View Post
36mm ?
Is that a question? Lol
Amps:
Old 01-13-2013, 05:01 PM
massivespl's Avatar
0/11 sssss8409
thats my guess. if the site says 18mm one way then it would have a total on 36mm both ways.
BL18
DUAL 1 | DUAL 2 Fs: 33.2 Hz | 33.2 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.82 | 5.82 Qes: .32 | .32 Qts: .30 | .30 Mms: 302g | 302g Cms: 0.88mm/N | 0.88mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 181.0 l | 181.0 l Spl: 94.1dB 1W/1m | 94.1dB 1W/1m Bl: 16.6 N/A | 22.7 N/A Xmax: 18mm | 18mm 18=18=36
Rms: 1500W * | 1500W * Sealed box: N/A cuft | N/A cuft Ported box: 5-8cuft | 5-8cuft Sub OD: 18.500” | 18.500” Cut ID: 16.750” | 16.750” Mounting depth: 9.750” * | 9.750” * Displacement: 0.26cuft * | 0.26cuft
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-13-2013, 05:06 PM
0/11 sssss1691
BL18
Rms: 1500W * | 1500W * Sealed box: N/A cuft | N/A cuft Ported box: 5-8cuft | 5-8cuft Sub OD: 18.500 | 18.500 Cut ID: 16.750 | 16.750 Mounting depth: 9.750 * | 9.750 * Displacement: 0.26cuft * | 0.26cuft
^^^ makes sence
Is that how u also put together a subwoofer? Put the tipof the former halfway down the motor
Amps:
Old 01-13-2013, 05:09 PM
AudioPsiho's Avatar
psihič
0/11 ssssss560
when u hear some bumpin sounds from your box(sub) thats tooooooo much Xmax (Xmech)
Old 01-13-2013, 05:11 PM
0/11 sssss1691
And how can u measure that!!!
Amps:
Old 01-13-2013, 05:21 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
You looking for the xmech which is the maximum one way travel before something stops the sub from going further. Whether it be the coil bottoming out or the spider hitting the top plate or the surround reaching its limit.
SD2-12 Xmax lance.requa (Sundown Audio) 2 12-26-2011 08:25 AM
Level 5 xmax? Stitched (DC) 1 06-12-2011 10:27 AM
xmax ??? LoudCavi General Car Audio Discussion & Questions 20 01-30-2011 11:24 AM
PG xmax 10 dacheatham Wanting to Buy (WTB) 0 11-19-2010 03:28 PM
Xmax How much is needed? sqonly Sound Quality Area 63 11-18-2010 07:42 AM
