XS Power battery upgrade - Car Audio Classifieds!
Old 01-14-2013, 12:15 AM
0/11 sssssss21
Default XS Power battery upgrade
So here is what's going on, I currently have a big battery from autozone but it isn't enough to keep up with my Sundown 100.4 and 2000. I am planning to get a XS Power XP3000 and I was wondering if I should use it as a secondary battery or if I should get rid of my current primary that I have and use the XP3000 as primary? Also I have a stock alternator and that will be my next upgrade after I get this XS power battery.
Old 01-14-2013, 12:16 AM
0/11 ssssss579
XP series is only meant to be used as a secondary battery.
Old 01-14-2013, 12:17 AM
tacomaguy1's Avatar
0/11 sssss4401
Corrrect...if you want a big one under the Hood could always do a d3100
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 01-14-2013, 12:24 AM
0/11 sssssss21
I did not know that the XP series was for secondary use. I did have the D3100 in mind but I figured that it wouldn't be much difference between the two before I knew this fact. So I guess I will stick with the D3100
Old 01-14-2013, 06:44 AM
massivespl's Avatar
0/11 sssss8409
i would keep the battery under your hood and put a 3100d in the back. two batteries are better then one. the best thing to do would be put the biggest XS battery u can fit under the hood and then put a XP3000 in the back
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-14-2013, 07:09 AM
got160s?'s Avatar
0/11 ssss13630
I would either use a 3000 as a secondary battery or what i would personally do is get the biggest battery you can fit under your hood and use that. If you plan on upgrading I would recommend getting a HO alt though.
What kind of wiring do you have done?
Have you done the big 3?
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
XS Power s3400 battery w/xs power I bars deepsilencer Wiring, Electrical & Other Installation Equipment 11 06-07-2012 09:03 PM
battery!!! xs power battery!! eddiemoua94 Wanting to Buy (WTB) 6 07-23-2011 05:55 AM
If I upgrade my inline fuse will I receive more power from my amp? atxbasshead General Car Audio Discussion & Questions 10 09-28-2010 08:42 PM
my sons power wheel upgrade(quick) lileddie1127 Build Logs 22 04-22-2010 11:57 PM
