List of clamped power numbers - Car Audio Classifieds!
Old 01-14-2013, 08:19 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Default List of clamped power numbers
Link to original/unlocked thread
Addictive Audio 500.1s (17.83v)
-Drop in the 15s?
-nominal 0.35 ohms rising to 1.4 ohms
-9497.4 watts
- Voltage drop - 11.4
-.67 nominal. Rise to 1.04
-4759 (clean)
starting at .25 Rise to .7
Voltage drop to 12.5
Power 6154w
American Bass 1100.1
-wired.5 rise to 1ohm
-Drop to @ 10.1vdc
-7656w
American Bass VFL 1100.1 LV
-Starting at 14.1 dropping to 13.2
-Nominal of .25 Reactive of .6
-14,200w clamped consistantly
(2) American Bass VFL 1100.1 LV's Strapped
-Starting at 14.1 dropping to 11.7
-Nominal of .5 Reactive of 1.2
-26,300 watts consistantly
American Bass 750.1
-Drop to 11.25 volts
-Rising to 1.03ohms
-6640w
(2) American Bass VFL 500.1's strapped at 1ohm (17.8v)
-rising to 2.4
-dropping to 15.5
-13,200 wrms
-Wired to .5 rising to 1.8
-Starting at 14.9v dropping to 14.xx (lows 14s)
-3460 rms
American Bass VFL 150.1
-.4 ohm nominal. Rise to 1 ohm exact
-drop to 13.3
-2,981 watts
American Bass VFL 100.1
-1 ohm nominal rising to 2.1
-Drop to 13.2
-1,335w.
-.5 nominal rising to .9
-Drop to 12.3
-1,858w
Audiopipe 1500d
-.7 ohm nominal. Rise to 1.2 ohm
-drop to 14.3
-1,683 watts
Audiopipe mini 1000d
-1 ohm nominal. Rise to 1.3
-Drop to14.8 volt
-893 watts
Audiopipe mini 1500 (APSM-1500)
-.5 nominal rising to .96
-13.8 to 13.5 Volts
-1550 watts CLEAN (gains set with scope)
Audiopipe APSM1000D
-.5 nominal. Rise to 1.6
-Drop to 13.0v
-1156w
Audiopipe AP1500.1
-Starting at 14.6v dropping to 13.6v
-starting at .5 ohms Rise to 1.06 ohms
-Power: 1859 watts
AQ2200
-Rising to .9 ohms
-2,538w @ 11.4v
-15.5v - 3,365w @ 13v
AudioQue 2200.1
-.5 nominal. Rise to 1.7
-Drop to 12.8v
-1,900w
AudioQue 2200.1
-1 ohm nominal. Rise to 3.1.
-Drop to 12.7v
-1,582w
Audioque 3500 (old version)
-wired at 1ohm rose to just over 3ohms
-start voltage=14volts, dropped to 12.6
-1,438rms clamped power
AQ 3500.1
-.7 Nominal, Rise to 4.5 ohms
-Starting Voltage, 13.4, drop to 13.1
-~1050 watts clamped
(2) AudioQue 3500D.1's (strapped)
-2 ohm nominal, rise to 6.5 ohm
-Dropping to 12.5 volts
-5500 watts
(^^Same amps^^)
-.5 ohm nominal, rise to 1.4 ohm
-Dropping to 10.5 volts
-9200 watts
AudioQue 20k
-1.925 ohms final load
-Dropping to ~13V
-8,233.86w
AudioQue 20k
-Rise .97 from .5
-starting voltage 14.8 dropping to mid 12's
-Power:11,382 watts
B2 Audio Quota (1200w)
-1 ohm nominal rising to 1.8
-14v.
-1,400w
-.5 nominal rising to 1.1
-13.8v.
- 1,800w
B2 Audio Zero5
-Rising to .9ohms
-13v- 4,052 @ 11.3v
-15.5v - 5,355w @ 13v
Cactus pf600.1
-.25 nominal. Unknown rise
-14.4v dropping to 11.5
-4,000w clamped power
Cactus PF600.1
-14.7v to 11.8v
-.35 rising to 1Ω
-2,350 (rms. clean)
Cactus K12
-starting .5 ohms rising to 1.2 ohms
-voltage starting 13.4 dropping to 11.0 FAST
-9,500+w rms
Cadence ia 9
-1ohm nominal rose to 1.54
-15.3 volts dropped to 13.4
-clamped 2,092 watts
-.5 nominal rose to 1.38
-15.3v dropped to 13.1
-clamped 2,648 watts
Cadence C6
-wired to .5 ohm imp rise to 1.04
-Unknown voltage
-5261 clamped watts
Cerwin Vega Stroker Pro 2000.1
-.5 nominal rising to 1.54 ohms
-Drop to 12.5v
-2,250w
Crossfire BMF 600.2
-14.8v dropping to 12.3v
-1 ohm nominal, 2.12 ohms reactive
-1325 w
DB Drive Okur a7 2000.1d
-Rising to 1.5,
-dropping to 13v
-1,836w
DC 3.5k
-1 ohm nominal riding to 2.4
-Drop to 13.2
-2,211
DC 7.5s strapped at .7.
- .35 per amp reactive 1.15..ohms
- Unknown voltage
- 17,406 watts
DD M3a
-Rising to .9ohms
-13v - 3,657w @ 11.2v
-15.5v - 4,088w @ 13v
(2) Digital Designs M4S strapped at .7
-rising to 1.9
-dropping to 12.6:
-11,925watts
Digital Designs M1b
-Starting at 14.6v dropping to 13.5v
-starting at .5 ohms Rise to 1.08 ohms
-Power: 2209 watts
2 Digital Designs M1B's strapped
-1ohm nominal. .5 for each amp rising to 5.58 ohm reactive
-15.4v. Unknown drop (stock electrical)
-1,324.4watts
Digital Designs M2a
-Starting at 14.6v dropping to 13.2v
-starting at .5 ohms rise to 1.08 ohms
-Power: 2506 watts
Digital Designs M2A
-starting @ .5 ohm rise to 1.5 ohm
-12.5v starting @ 14.6v
-2,400w
-.5 rise to 2.2 ohm
-12v flat starting @ 14.7
-1,754w
(2) DD M2a's Strapped
-starting imp of .25(peramp) unknown rise
-starting voltage of 14.4 dropping to ? I forgot
-5400w
Digital Designs Z2HV
-Starting @ 17.5V
-Reactive imp: 0.935 ohm
-12811 WRms
Digital Designs M3 (round silver heat sink)
-14.4 drop to 12
-.25 rising to .85
-4,300w
-1 ohm rising to 3.3 ohm
-12.8v starting @ 14.2
-2200 watts
Hifonics Colossus XXV
-2ohms nominal. Rise to 2.75ohms
-Voltage drop to ~12.3-12.7
-Clamped 2,880 rms
Hifonics BRZ 2100.1
-1.3 nominal. Unknown rise,
-Voltage drop not measured.
-1,848w
Hifonics Thor 3,000
-Car Off
-6 ohms rising to 15 ohms
-386 watts
Hifonics BRZ1200.1
-Starting at 14.6v dropping to 13.7v
-starting at .5 ohms Rise to 1.1 ohms
-Power: 1391 watts
HiFonics brz2100
-wired to 1 ohm rise to 1.67
-13.6 volts dropped to 11.8v on 70amp alternator
-clamped at 1735 watts
Incriminator Audio 40.1 (new style. 17.5v)
-drop to 15.2v
nominal 0.35 ohms rising to 1.08 ohms
-8,878w
Incriminator Audio 20.1
-drop to 12.4
-.5 nominal rising to 1.6
-1,985w
Incriminator Audio 20.1 (17.9v)
-drop to 16.1v
-0.35 ohms rising to 1.15 ohms
-4554.9 watts
JL Audio 1000/1
-Starting voltage was 16.5v on a 40A charger (truck off)
-Drop to 12.5v
-2.8 ohm nominal rising to 5.1 ohms
-1,674w
Team CACO Team SHOK
Supporting Member
Old 01-14-2013, 08:20 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
1997 Lanzar Optidrive 2500 (rated at 1000w @ 4 ohm)
-Wired to .5 rising to 1.75
-Starting at 14.4v dropping to 13.0v (with one Hawker HX300 Battery)
-1886 w
-Wired to 2 rising to 5.19
-Starting at 14.4v dropping to 13.4v (with one Hawker HX300 Battery)
-1260 w
Lanzar Vibe 1800d
-.5 nominal. Rise to .9 ohm
-drop to 14.2
-1,975watts
(2) MB Quart DSC2000's strapped at 1ohm.
-Rising to 3.87 ohms
-14.5v drop to 13.0v
-3,720 watts
MB Quart DSC 1500d
-Drop to 12.5
-Starting load-2ohm
-Rise- 3.7ohm
-544w rms
Mmats 4000.1
-wired to 1 ohm
-imp rise to 2.2
-3147 clamped watts
PowerBass ASA 1000.1d
-1 ohm nominal. Rise to 2.23
-Drop to 14.0
-1,251w
PowerBass ASA 1500.1dx
-1 ohm nominal. Rise to 2.5
-Drop to 13.6
-1,525w
Powerbass 5k
-.7 ohm nominal. Rise to 4.9
-drop to 13.9
-1,753 watts
-.7 ohm nominal. Rise to 1.89
-Drop to 12.9
-4,790 watts
RD D5
-Rising to .9ohms
-13v - 3,898w @ 11.1v
Rockford Fosgate t4000bd (16.5v)
-.3 ohm nominal. Rise to .7
-drop to 14.7
-4,856 watts
Shok II ([email protected])
-.5 nominal rising to .72
-Drop to 13.3
-3,523 watts
-1 ohm nominal rising to 3.13
-dropping to low 12's
-1,516 watts
SounDigital 5k
-7,139w rising to 1.95 & 11.5v clipped. No, I am not kidding.
-4,324w rising to 1.95 clean. Zero clip light
SounDigital SD8000.1D
-Wired to 2 rising to 4.52
-Starting at 14.4v dropping to 12.6v (with one Hawker HX300 Battery)
-3053 w
SounDigital SD16k
-4 ohm nominal rising to 10.6 ohms
-Starting @ 19.2v and dropping to 16.5v
-5,904.72 Watts
-1 ohm nominal rising to 2.5 ohms
-starting @ 19.2v and dropping to 15.4v
-13,805.52 Watts
SoundStream DTR1.3400.1
-.35 nominal. Rise to 1.2ohms
-Voltage drop - 12.1v
-Output - 2,679w
SoundStream DTR1.1400.1
-1ohm nominal. Unknown rise
-1,341w
SoundStream 15000d amp
-.8 nominal. Rise to 1.87
-Drop to 15v
-8,732w
Soundstream XXX-10000D (18v)
-.7 nominal. Unknown rise.
-drop to 17.3v
-9,120w on gain half with 2v preouts
Sundown Audio SAE-1200D V.1
-1ohm nominal, rise to 2ohm exactly
-voltage drop to 12.3v
-1,204 watts
Sundown 1500d
-1 ohm nominal. Rise to 2.86
-Drop to 13.5
-1,156 watts (clipped).
-590.4 watts (clean)
(2) Saz 1500's (not strapped)
-Nominal load .66. Rise to 1.2ohm (each)
-Drop to 12.9
-Total clipped power 4,536w, Total clean power 3,248w
Sundown SAZ 2500 with dual inputs
-.5 rising to .65 (yea box rise = almost non existant)
-drop to 14.2v from 15.8 (14v electrical d1400s alts at 15.8v)
-3320rms
Sundown SAZ 2500
-1 ohm nominal rising to 1.75.
-Unknown drop
-2,320w
(2) SAZ 2500s (not strapped)
-.5 nominal rise to .9
-drop to 12.5volts
-4,430 watts total, 2,215 from each amp
(2) Sundown SAZ 2500Ds Strapped
-Started at 14.4 and dropped to 13.1
-Unknown ohm load
-4962.8 watts
Sundown 3000d
-.5 nominal with rise to : 1.4 ohms
-voltage drop to: 11.5v
-3,055w clamped.
(2) Sundown SAZ 3500d's (not strapped. 17.1v)
-.4 per amp nominal rising to 1.4 ohms
-dropping to 15.8v
-8,980 rms total. 4,490w per amp.
Sundown 4500D
-.7 ohm nominal. Rise to 2.2
-Drop to 13.0
-3,911 watts (clean)
Sundown NS-1
-Drop to 11.50 volts
-Rising to 1.06ohms
-6470w
Digital Designs M4a
- rising to 3 ohms
- Drop to 9.5v (yeah, stock electrical. What of it?)
- 3,695w
Hifonics xx-chaos (20th anniversary. bridged)
-1.4 rise to 2.03ohms
-Drop to 13.9v
-1843rms
Same amp on seperate channels
-.7 rise to 1.12ohms
-Drop to 14.0v
-871rms per channel
Skar 4500
- Rising to 1.2ohms
- Drop to 13.5v
- 5,600 (clean)
- 6,300 (soft clip)
- 7,600 (clipped to hell and back)
(2) B2 Zero1's
-.5 strapped rising to 1.5
-14.8v dropping to 12.7v
-116.9 volts x 76.7 amps= 8966 watts
Team CACO Team SHOK
Supporting Member
Post your clamped numbers. TaylorFade General Car Audio Discussion & Questions 447 04-11-2016 05:47 PM
The clamped numbers post has gotten too big!! TaylorFade Talk with the staff 14 01-14-2013 09:34 PM
SAZ-2500 Clamped Numbers? Anton Miller (Sundown Audio) 4 05-30-2012 07:42 AM
Clamped Power? oldsboomer (Crescendo) 15 08-20-2010 01:26 PM
Bangin On A Budget 605 Clamped TL Numbers J&T DESIGNS Car Audio Videos 6 05-25-2010 06:41 PM
