Tinsel lead question and why tinsel? - Car Audio Classifieds!
Old 01-15-2013, 10:40 PM
beatnbronco's Avatar
0/11 sssss2284
Default Tinsel lead question and why tinsel?
I'm building a pair of 18's and got to thinking back to the first pair i built years ago that I fried the tinsel leads in half on with an AP3K, so i want to avoid that happening again to an even more expensive build. If I was going to use the AP3K on a pair of 18's, how many watts worth does the lead need to handle? Instead of running single runs of 3000 watt rated tinsels across the spiders, would it be that same to use 3 runs of 1000 watt rated leads? If it would be the same to run 3-1000 watt rated leads, do i run 3 to each coil wire?
One last thing that bothers me too...what is it about tinsel wire? What is in it that makes a thin piece of wire handle 1000-3500 watts? 8 gauge power wire or speaker wire directly to the coil wires won't work? Why
Man that was hard to word right! Sorry if it might not've sounded right but i hope someone can help...thanks
Old 01-15-2013, 10:43 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
short distances handle higher amprege
Old 01-16-2013, 11:16 AM
0/11 ssssss855
From my understanding the tensil leads smoke or heat up because of clipped power I ran a hifonics on a pair of zcons 12s clamped 7 k rms then sold the amp tryed them on a pair of ap 1500s and smoked the tensils leads .. now I have a friend same issue with a preformance technique amp smoke sa15 tensils cuz he was clipping
Old 01-16-2013, 12:11 PM
Mr.G6's Avatar
0/11 sssss4614
tinsel leads are rated in amps not wattage
2000 Gmc Sonoma ext cab
Old 01-16-2013, 12:17 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
It can convert over
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 01-16-2013, 12:22 PM
Mr.G6's Avatar
0/11 sssss4614
Originally Posted by logan23afroman View Post
It can convert over
well no kidding.. i was just clarifying it up.. that tinsels are rated for amps not wattage..
thats exactly what alan hall told me this morning
bc i askd him what tinsels for 2000w and he said "its silly to say tinsel and wattage in same sentence" "tinsels are rated for amperage"
Broken Tinsel Lead jimmay General Car Audio Discussion & Questions 2 12-06-2011 11:55 PM
Tinsel Lead Repair TheJesus General Car Audio Discussion & Questions 14 05-24-2011 11:21 AM
Wtb. Tinsel lead wire dumple Wanting to Buy (WTB) 1 04-19-2011 02:08 AM
Tinsel Lead Failure? ascitiesburn69 General Car Audio Discussion & Questions 8 03-21-2010 03:43 AM
WTB tinsel lead YouSirName Wanting to Buy (WTB) 4 03-07-2010 11:34 AM
