Finding port length on odd shapes? - Car Audio Classifieds!
Old 01-16-2013, 11:02 AM
Matt3824's Avatar
0/11 sssss3754
Default Finding port length on odd shapes?
I've always wondered this but never run into a situation where I needed to know....until now. How do you find the port length on an odd shape using a port calculator?
Old 01-16-2013, 11:08 AM
Prohibited Sellers/Buyers
0/11 sssss1326
find the sq inches of the port area. ie. if its triangle. width by height divided by 2 and then find sq rt of this number and use a port calculator at with width by height of that number.
doesnt neccesarily have to be sq rt. could be two numbers that multiply together to reach the area.
Old 01-16-2013, 11:10 AM
0/11 sssss1326
This will not be exact, as the shape of the port and its interaction to internal walls plays a part in the role , but this will get you close enough that you wont hear a different to the ear.
Old 01-16-2013, 11:38 AM
Matt3824's Avatar
0/11 sssss3754
I figured that. Just wondered if there was a "correct" way. Thanks.
Old 01-16-2013, 01:36 PM
tntahoe's Avatar
0/11 sssss1196
just make sure that the port is uniform throughout
Old 01-16-2013, 05:51 PM
Benny33's Avatar
Hockey players, man...
0/11 sssss1616
Back in math classes when you were saying "I'm never going to use any of this crap", this is when you need to use that crap.
Yous just figures that out? All the hots ones is crazy!...And deh ugly ones too. - Toki Wartooth
The Following 2 Users Say Thank You to Benny33 For This Useful Post:
KTMrida4life (01-16-2013), marcotheclepto (01-18-2013)
Old 01-16-2013, 06:21 PM
Matt3824's Avatar
0/11 sssss3754
Lol. Fortunately I was never that student. The class I was in, we were learning trig and precal freshman year.
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 03:01 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
finding 10" aero port, port calculation help darkkon General Car Audio Discussion & Questions 6 07-24-2011 07:26 PM
port length help dylan9999 General Car Audio Discussion & Questions 8 07-07-2010 02:18 AM
