Confused xs d7500/d6500 - Car Audio Classifieds!
Old 01-16-2013, 11:52 AM
Slam's Avatar
I slam
0/11 sssss3772
Default Confused xs d7500/d6500
If the d6500 specs are:
58lbs
1070 mca (marine cranking amps not cca)
75ah
6500watts
and the d7500 is almost double the above specs why is there only a 1000w difference between the 2 batts
1700 ca (again at 32c)
140ah
7500watts
I asked myself is there a difference in other d series batteries. Yes, the d2400 is double the specs than the d1400 however it is double the power according to the power handling wattage.
Maybe I missed something......?
Originally Posted by [email protected] View Post
No the 4 D6500 would be stronger. Easy way to determine that is by the weight of the batteries when you are comparing XS Power batteries v/s XS Power batteries. All of our D series batteries are designed and manufactured the same way, so pound for pound they will be close on power.
4 D6500 would be 232lbs v/s 200lbs in 2 D7500. The weight is made up of the lead in the battery for the most part and the lead is what makes the power and capacity.
Also, when you hook up multiple batteries together it optimizes the internal pressure and allows them each to produce more power individually.
3 D7500 would be stronger than 4 D6500 though.
Old 01-16-2013, 12:12 PM
0/11 sssss1016
The D6500 is only good for around 4000 watts as a secondary battery for daily use. The D2400 is a 12V battery and the D1400 is a 14V battery, so the 14V is going to have less capacity, because it is a 7 cell battery.
http://www.4xspower.com/XSpower-Mobi...ure-LowRes.pdf
The ratings are BCI Standard CA (cranking amps).
'1.888.497.7693 x1211
Old 01-16-2013, 12:19 PM
Slam's Avatar
I slam
0/11 sssss3772
ah. Thought the wattage of the d series is the number behind the "d"
Guess I should have looked at the voltage when comparing the other 2 lol
Old 01-16-2013, 12:23 PM
knowledge's Avatar
0/11 sssss2548
hmmmm great point
Old 01-16-2013, 12:24 PM
0/11 sssss1016
That is easily confused. Our part numbers for our D series D3100-D4700 are actual BCI Group size batteries. Example the D5100 is a Group 51 battery, so it would fit under the hood in any application that uses a Group 51 battery. The D3400 is a Group 34 battery and would fit in Group 34 applications.
The XP batteries part numbers are based on wattage, since they should not be used in starting applications under the hood.
The 1200-375 are not actually BCI Group Sizes, but are recognized sizes in the industry (mostly racing).
Old 01-16-2013, 12:35 PM
Slam's Avatar
I slam
0/11 sssss3772
Thanks for clearing it up.
Just trying to find the best batteries for my set up. 2 40.1 and a dc-power 320hp alty. Dont need alot of weigh.
Old 01-16-2013, 12:41 PM
0/11 sssss1016
What vehicle is it going into?
Old 01-16-2013, 12:45 PM
Slam's Avatar
I slam
0/11 sssss3772
Honda civic wagon van. Have all the space needed in the back
Old 01-16-2013, 12:48 PM
0/11 sssss1016
How much power for the system and is it mainly for comps and demos?
Old 01-16-2013, 01:00 PM
Slam's Avatar
I slam
0/11 sssss3772
I will try and get every bit of power from the 40.1s so im going to say around 10-14k watts for comps.. Prices would be appreciated too plz
D7500 view from ces [email protected] General Car Audio Discussion & Questions 36 01-20-2013 04:07 PM
2 XS power d6500 Rocken JBL Wiring, Electrical & Other Installation Equipment 15 11-20-2012 11:34 PM
D7500 Shiping December [email protected] General Car Audio Discussion & Questions 50 11-07-2012 07:15 AM
WTB: 2x XS D6500 TheJesus Wanting to Buy (WTB) 8 10-04-2012 01:51 AM
Bnib d6500 armykyle1 Wiring, Electrical & Other Installation Equipment 0 07-24-2012 08:27 PM
