OPTIMA’s Digital 1200 12-Volt Charger - Car Audio Classifieds!
Old 01-16-2013, 11:27 PM
0/11 ssssss163
Default OPTIMA’s Digital 1200 12-Volt Charger
Any one use this charger. Seems to be a good one. I have to buy a AGM Charger. This thing is like 200 bucks. What do you guys think.
Tech Tips 8: Using an OPTIMA® Digital 1200 Battery Charger & Maintainer - YouTube
http://www.summitracing.com/parts/ul...FY9DMgod03QAsw
http://www.optimabatteries.com/us/en/products/charger/
Old 01-17-2013, 02:20 AM
0/11 ssssss163
bump really wanna buy this. Need your opinions please.
Old 01-17-2013, 04:52 AM
Mr.G6's Avatar
0/11 sssss4614
rather buy a deltran battery tender plus for 60 bux does the same exact thing
but a better warranty
i seen NOTHING that makes this worth the asking price.. a xs power intellicharger is the same price.. ive owned 1..and sold it for a deltran
rather own this better unit for now 45bux ( was 60 when i got mine)
http://www.ebay.com/itm/Deltran-Supe...80ddb0&vxp=mtr
2000 Gmc Sonoma ext cab
Old 01-17-2013, 04:55 AM
Mr.G6's Avatar
0/11 sssss4614
that things about 1 step away from being a computer
Old 01-17-2013, 05:22 AM
0/11 ssss31256
forget the tenders man... I want something that does THIS;
How to Desulfate a Lead Acid Battery | NOCO Genius® - YouTube
understand that even AGM batteries ARE lead-acid batteries.. the acid is just Absorbed in the Glass Mat.
Old 01-17-2013, 05:56 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
I would Never. Ever. Buy that for a car audio application. Sure, it may work great if you have say ONE battery, but as soon as you were to add multiple's it would take absolutely forever for it to top things off. God forbid you want to charge something fast. OP if you're spending that much money, I'd just make sure the charger has all the features you need (different charge rates, battery types, possibly engine start, de-sulfating mode, etc.)
-Youtube Channel
Old 01-17-2013, 11:23 AM
Mr.G6's Avatar
0/11 sssss4614
really? bc i have it hooked up 24/7 to 400amp hr of battery
and every single 1 of them were sitting in the low low 12v range.. took 1 day to top them all off
it takes around 2hrs to charge 1 battery 100%
your not supposed to charge over 2.2v per cell
using a 10 to 15amp charger for 1 battery is going to cause ALOT of heat and over repeated charge times itll weaken
Old 01-17-2013, 11:25 AM
Mr.G6's Avatar
0/11 sssss4614
a standard wetcell charger will swell up a agm in no time at all
yes they are just another form of lead acid battery
agms charge a DIFFERNT way than a standard wetcell does
but its whatevr
go spend 300 on a GOOD battery and use a 10yr old wetcell charger on it
itll swell within the 1st few times
Old 01-17-2013, 11:28 AM
0/11 ssss31256
yer' silly
taylorpro (01-17-2013)
Old 01-17-2013, 11:41 AM
Me > Lord Van
0/11 sssss2831
There's a big difference between a maintainer/tender and a charger.
A maintainer is designed for exactly that, maintaining. They take a long time (by comparison) to charge batteries fully.
A good CHARGER will have multiple charge settings depending on what you have it hooked up to.
Also, it depends on the speed at which you want to charge your batts. For someone like me who competes, I need a charger that can charge my bank relatively quickly (i.e. higher amperage settings).
I actually use both maintainers and chargers. My truck sits on a maintainer year round when not in use. This keeps my bank "topped off" and keeps the batts in good condition. However, when I'm competing or testing I have my xs power charger hooked to it in order to recharge my bank relatively quickly.
Both items have their respective duties.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
XS POWER 12 volt battery charger crunkjuice1 Wiring, Electrical & Other Installation Equipment 5 06-19-2012 09:48 PM
xs power 12 volt agm charger mack30 Wanting to Buy (WTB) 2 11-27-2011 06:16 PM
12 volt battery charger mrfantastic911 General Car Audio Discussion & Questions 13 07-20-2010 03:58 PM
Decent trickle charger for 12 volt basshead08 General Car Audio Discussion & Questions 4 12-18-2009 09:09 AM
