need help with belt tensioner - Car Audio Classifieds!
Old 01-16-2013, 11:36 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default need help with belt tensioner
I am installing dual alts on a truck, and the only way to do it with how the alts are mounted is to either add another pulley, or switch the direction the belt tension-er pulls.
is it possible to change the direction the tensioner pulls?
if you need me to draw up a diagram I will just let me know.
Old 01-16-2013, 11:49 PM
DonH's Avatar
0/11 sssss6645
it depends.... on my burban it would hit brake lines... a tension-er is a tension-er as long as it is not obstructed from movement because its constantly adjusting and moving....
Old 01-18-2013, 04:07 PM
btsteinb's Avatar
0/11 sssss3573
Thanks don got it all figured out.
Sent from my PG86100 using Tapatalk 2
belt slip on 97 explorer baaudio (Singer) 5 04-20-2012 03:24 AM
Serpentine Belt Question lance.requa General Car Audio Discussion & Questions 6 02-01-2012 01:57 PM
I need help with an alt. belt for a Scion TC Ashtabula Jim General Car Audio Discussion & Questions 3 01-10-2012 01:35 PM
I want this belt buckle korey_hofer Off Topic Chat 30 12-20-2010 11:05 PM
Dice Belt Buckle worstenemy453 Miscellaneous Stuff For Sale 0 02-26-2009 07:27 PM
