Need opinons! Efficiency vs Powwaaa! - Car Audio Classifieds!
Old 01-17-2013, 09:24 AM
0/11 ssssss461
Default Need opinons! Efficiency vs Powwaaa!
Just put my HDC3 12's in my Edge. Threw them in a temporary box until I get the funds for a new one; at least that was the initial plan, but I'm finding they actually sound quite good in the temp box. It's 3.25cf @ 32hz. I was quite surprised how good they sound based on the fact that the box is barely big enough for my old HDC3 10's to be happy. Apparently the new version with the bigger, softer spiders likes smaller boxes better.
ANYWAY, the output is good, but not great. I'm guessing it's doing about 135-40dB from 30-60hz. But I know there's a lot more in them. Even running full tilt off of my AQ2200 @ 1ohm, they're only moving about 1 inch p-p. So my question is: go with a bigger, more efficient box or double up the power and get another AQ2200? The bigger box would be cheaper, but I'd be sacrificing more space in the hatch and I'm not sure how much I could gain by going to say 5cf @ 36hz. Doubling power would definitely increase output, but would also be more expensive since I'd also need another battery.
So here's where I turn the mic over to you guys. Ready? Go!
Old 01-17-2013, 10:06 AM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
What about a different arrangement close to same specs? Is your current box all back or subs up/port back? But I'm sure you will gain with a little bigger box, definitely lower frequencies... build big, tune high.
Say a 5 cube box @ 36hz keep low output and wake up higher notes
Sent from my DROID X2 using Tapatalk
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 01-17-2013, 10:09 AM
0/11 ssssss461
Current arrangement is subs up, inverted. Port on passenger side. Like I said, I was really surprised how good this temp box sounded. If I could keep the same frequency response, but add 6dB, I would be ecstatic!
Old 01-17-2013, 10:54 AM
massivespl's Avatar
0/11 sssss8409
build a box for those subs and it should be like night and day. its all about the box/install. but forsure they can handle more power then a AQ 2200. anyway hit me up for a demo sometime. i wanna hear yours and u can take a listen to mine
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-17-2013, 11:02 AM
0/11 ssssss461
I'm thinking box now, more power later. Gonna keep my eye out for someone who wants to trade a BC3500 for an AQ2200. The orange design on those matches my car perfectly and I know they're good amps for the money. Already sent double 07 a price quote for a box.
Old 01-17-2013, 11:17 AM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
You try flipping them around. I gained 4 db flipping mine around.
Sent from my PG86100 using Tapatalk 2
Old 01-17-2013, 11:20 AM
0/11 ssssss461
You mean port to drivers side? Which way was louder for you?
Old 01-17-2013, 05:52 PM
massivespl's Avatar
0/11 sssss8409
i thought your system sounded good from your demo today. not bad for stock everything other then amp and subs.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-17-2013, 06:46 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
I say build a box as large as u can go.. do u plan to keep subs inverted? A new box would do wonders!
As reference i was doing a 145 with 2 12w7's on 1k rms sealed legal..
Those HDC's can get much louder than some SQ JL's.
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 01-17-2013, 07:03 PM
massivespl's Avatar
0/11 sssss8409
if i had to guess with my ear-o-meter says hes around a 142db right now.it was decent.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Average efficiency? basshead08 General Car Audio Discussion & Questions 3 05-30-2011 10:13 PM
need opinons on new head unit! ront337 General Car Audio Discussion & Questions 3 11-14-2010 05:37 PM
front stage opinons Burbarry General Car Audio Discussion & Questions 9 09-28-2009 01:43 PM
Thoughts/ opinons. BIG_SUPERMAN72 General Car Audio Discussion & Questions 0 08-02-2009 09:44 PM
