1, 2, or 4 amps that equals 14000 @ 1ohm - Car Audio Classifieds!
Old 01-17-2013, 08:15 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
Default 1, 2, or 4 amps that equals 14000 @ 1ohm
I want to run 4 15's at 3500 clamped watts per sub. If you guys can help I want full list of amps I could use. Like 4 amps at 3500 each or 2 at 7000 each or 1 at 14k. This will be at 1 ohm (after rises) and hopefully I'll stay between 14-15 volts. If u guys could help and point out some pros and cons of each that would be great. So far I've found: dc 3.5k, saz 3500, dd m4a, and ns-1. (Please talk about these as well)
Old 01-17-2013, 08:18 PM
1/11 ssssss892
Dc 7.5k.....
Contributor
0/11 ssssss527
I would look into two DC 7.5Ks to make your life easy, then you don't need a mutant amp but you don't need four either.
EDIT: Ninja'd
Old 01-17-2013, 08:21 PM
Veteran Member
0/11 sssss3359
that's what im running for rated power. however i run my 3500's at .5 and have clamped as high as 4700 watts individually. never tried clamping all four together though
Old 01-17-2013, 08:26 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
EDIT: Ninja'd
I was thinking about the 7.5k's but do they actually get 7.5k out? If so it might be much... butI can aalways dial the gains back huh?
Old 01-17-2013, 08:42 PM
1/11 ssssss892
Does rated at 12.8 iirc so doesn't more that rated at height voltages just make sure you have the electrical
Old 01-17-2013, 08:55 PM
DC98hoe's Avatar
Doing 156s below the seat
0/11 sssss1372
I clamped over 18k on mine
98 tahoe 4-team ascendant 18s ,2-Flatline 9.5s 18 v --singer 320 hairpins-4th order 160dbs
Old 01-17-2013, 09:03 PM
1/11 ssssss892
Yea what ^^^^^^ said
Old 01-17-2013, 09:18 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
You're talking about 2 together putting out 18k total right?
Old 01-17-2013, 09:19 PM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
2 dd m4a's, wont be disappointed.
F/S Us Amps Merlin Md1d [email protected] ampjunkielikeme Broken & Non-working equipment 1 06-23-2011 07:27 PM
Us Amps Merlin Md2d [email protected] ampjunkielikeme Mono Amplifiers 2 05-23-2011 02:41 PM
F/S #2 Us Amps Merlin Md2d [email protected] ampjunkielikeme Mono Amplifiers 1 05-22-2011 07:43 PM
I want a new amps/amps, any budget reliable suggestions?? .5-1ohm?? Vaginatarian General Car Audio Discussion & Questions 47 12-14-2009 11:38 AM
Smaller box equals higher rise? Jbgabriel Enclosure Discussion & Design Construction Help 5 01-10-2009 02:36 PM
