Help choosing a new amp and other questions - Car Audio Classifieds!
Old 01-17-2013, 08:38 PM
0/11 sssssss26
Default Help choosing a new amp and other questions
So Ive got a V1 Nightshade 15 in a 1.5 inch layered birch box all glassed and reinforced tuned at 28hz. Im currently running it off a AB ph4000md.
Car- 2010 Mazdaspeed3
Sub- 15 inch Sundown Nightshade V1
Amp- American Bass Phantom PH-4000 md
Headunit- AVH-4400bh
Front battery- Diehard Platnium 34
Rear Battery- Kinetik HC800 x 2
As far as the wiring im currently running 2 runs of 4 gauge OFC, soon to be replaced with 2 runs of SHOK 0 gauge.
I went from two SA12s to the nightshade and while it sounds so much better I feel like its just begging for more power. So, suggestions?
My goal is to hit 145db. Is that possible with what ive got?
Thanks.
Old 01-17-2013, 09:08 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
How many cubes is the box?
Old 01-17-2013, 09:13 PM
0/11 sssssss26
3.4 i think, i could be wrong.
I can measure everything if that will help.
Old 01-17-2013, 09:27 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Your cf seems ok is it a slot ported or an aero port that ns would come alive if th box was tuned higher around 35ish hz.
Old 01-17-2013, 09:47 PM
0/11 sssssss26
Its a slot port, How would I go about tuning the box higher?
Old 01-18-2013, 05:12 AM
0/11 sssssss26
Would I be able to buy to AP mini 1500s and put one on each coil?
The sub is dual 2 ohm.
Old 01-18-2013, 06:21 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Your current amp is 4000rms and better than 3 of those ap Mimi's it's never a good idea to run one amp per coil on a sub your port needs to be shorter to tune higher double check the sub if it is pulling 1-1.3ohms out of the box you have a nice amp and sub your just missing the proper box for that sub
Old 01-20-2013, 06:55 PM
0/11 sssssss26
My amp wont do 4k. Its more like 1900rms.
The box is a slot port, so after a bit of reading if i just add a block of wood in the corner i should raise the tuning correct?
The sub reads at 1.28 ohms.
If i invert it would I gain anything?
Old 02-17-2013, 07:55 PM
0/11 sssssss26
Bump.
Im gonna pick up a sundown 3k.
Would my electrical handle it?
Old 02-17-2013, 10:17 PM
vince79vette's Avatar
0/11 sssss2011
Originally Posted by eppopipe View Post
Bump.
I would say no. Those amps do 3k+ np. I would do the big 3 if u havent already and more batterys for sure to run that amp. A alt wouldnt hurt ether but batteries the most.
Sent from Chuck Norris foot
need help choosing an amp swerve225 General Car Audio Discussion & Questions 15 01-05-2013 06:13 PM
Need some help choosing amp for mids and highs swerve225 General Car Audio Discussion & Questions 4 12-08-2012 12:47 PM
First wall..Thoughts & Ideas & Port questions Travis.Iowa Enclosure Discussion & Design Construction Help 9 11-28-2012 03:26 PM
need help choosing a set of 6x9 & 6.5s 83eldorado General Car Audio Discussion & Questions 0 02-02-2012 10:00 PM
HELP! Choosing an amp moneil10 General Car Audio Discussion & Questions 8 11-28-2011 06:33 AM
