Bondo!! - Car Audio Classifieds!
Old 01-17-2013, 09:37 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Default Bondo!!
I'm in the middle of constructing a sub box for home theatre use. Since it's winter time, I used some today to fill over the drywall screws to prep for paint later. I used it while in my garage with the door shut. Being it's pretty cold outside, wondered how it would dry inside my cold garage?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-17-2013, 09:40 PM
0/11 sssss3842
Did you mix it according to directions? If so it will take a longer than normal.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 01-17-2013, 09:49 PM
0/11 ssss12531
Yuppers. Don't wanna drag it inside my house for room temperature drying, my wife might beat me. And it does stink, but most of us are used to it.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-17-2013, 09:51 PM
0/11 ssssss160
Heat it with a heat gun or hair dryer
Old 01-17-2013, 10:08 PM
0/11 sssss1417
should mix hot when its cold outside.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 01-18-2013, 01:35 AM
0/11 sssss5305
next time add more hardener, same way you do when mixing FG resin. You need to adjust for the temp, hotter or colder require diff amounts...
Old 01-18-2013, 02:15 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
bondo won't be effected too much by the cold.. resin is what can really have a problem with the cold in my experience. Resin has much greater surface area obviously.
Current Build:
#60sHereIcome
Old 01-18-2013, 07:36 PM
0/11 ssss12531
oooook we'll see what happens...
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-19-2013, 02:06 AM
0/11 sssss5305
depends upon how cold it is, but yes it's not as bad as resin but a little extra hardener on colder days does help. Especially when you're impatient and want to get it sanded in a hurry....
The Following User Says Thank You to mlstrass For This Useful Post:
rachidfunaki (01-19-2013)
Old 01-19-2013, 03:19 AM
0/11 ssssss723
Feedback Score: 31 reviews
If you mix a little thinner in it it will kick faster .
Ban me.then and.stop showing.his.childish the mods are here with these changes.to my sig
whats a good bondo/wood filler to use kurupt305 Enclosure Discussion & Design Construction Help 11 10-24-2012 09:43 AM
Sanding Bondo Fast? andale927 Enclosure Discussion & Design Construction Help 21 06-28-2012 04:21 PM
Bondo or similar substance JAYARE2007MAG Enclosure Discussion & Design Construction Help 3 04-08-2012 08:49 PM
All fiberglass box, how do I lay bondo smoothly?? did I bite to much?? NorthBeat General Car Audio Discussion & Questions 27 08-24-2010 10:41 AM
Evercoat Everglass, Duraglass, Bondo, ect..?? bangin_explorer General Automotive Chat 37 10-21-2008 02:02 AM
