1 ported IDMAX vs 2 sealed CMPX2 - Car Audio Classifieds!
Old 01-18-2013, 10:54 AM
0/11 ssssssss6
Default 1 ported IDMAX vs 2 sealed CMPX2
So I currently have a single 12" IDMAX ported in a non-ideal enclosure. It is in 2.4 ft with 19 inches of port at 33hz.
I just purchased 2 Crystal CMPX2 12s.
My goals are good SQ, something accurate for the most part, with a good level of SPL and something that can dig low (30hz and maybe a bit lower) with authority.
With that in mind, would you recommend running the Crystal's in a sealed box (not enough room for an ideal ported enclosure for both of them) or build a better box for my single IDMAX?
I currently have 1600 watts available for either setup. If I go with the Crystal's I may look for something that does 3000 watts or so.
Thanks!
From Ported to Sealed. Low_ToneZ General Car Audio Discussion & Questions 9 11-13-2012 03:41 PM
sealed or ported? kevmoney265 General Car Audio Discussion & Questions 1 06-25-2012 03:44 PM
sealed or ported?? bydapoundatl Enclosure Discussion & Design Construction Help 2 01-06-2011 05:00 AM
Sealed or Ported SKDooley General Car Audio Discussion & Questions 3 12-05-2010 07:04 PM
Ported or Sealed??? joebobclark Enclosure Discussion & Design Construction Help 3 06-23-2010 06:29 AM
