odyssey pc1700's - Car Audio Classifieds!
Old 01-18-2013, 11:04 AM
DroppedATLHoe's Avatar
0/11 ssssss403
Default odyssey pc1700's
will 3 pc1700's with a hc1800 under the hood support...8000rms?
i also have 4 300 amp alternators with a mla
i know someone with 12000rms with 3 bt120's in the back and a yellow top under the hood and full tilt dont drop under 13.8 with a dual alt setup
i know i have plenty of alt power so i figure i dont need to load up with a bunch of batteries and if 3 bt120 support much more power i figured 3 pc1700's should support 8k with out much voltage drop
Old 01-18-2013, 11:08 AM
0/11 ssssss461
I'm not an expert in this area, but I'd bet you'd barely even touch your battery reserve with that much alternator.
Mr.G6's Avatar
0/11 sssss4614
sounds like to me you answerd you own question lol
2000 Gmc Sonoma ext cab
Old 01-18-2013, 11:14 AM
0/11 ssssss461
I think he was just looking for confirmation.
Old 01-18-2013, 11:25 AM
0/11 ssssss403
yea i needed confirmation b/c i havent ran a system of this caliber before and even with the alts i was TOLD by someone thats been in car audio for 20+ years that it wasnt good enough bla bla bla.... and i was thinking on what i knew, forums and my ppl in general.
my highest powered system was 2.6krms total with stock alt yellow under the hood and yellow in the truck.
so before i spend money i like to get confirmation
Old 01-18-2013, 11:29 AM
Mr.G6's Avatar
0/11 sssss4614
ok say your alternators are putting out a legit 300a each thats 1200amps potentially
a good 8k rms system is only going to pull in the range of 600 700 or so amps MAYBE a tad more on burps etc etc..
so your basically at 1/2 your alts capacity.. with 3 1700s and a 1800 i HIGHLY doubt you will see anything below mid 13v range
Old 01-18-2013, 12:28 PM
0/11 ssssss403
when the alts were benched, the lowest one was 317a, so power's there
i figured about 600amps would be needed to maintain my rms and this is a daily system. no burps, demo's but no burps
gonna go ahead and pick up these batteries tonight or tomorrow
Odyssey PC1700 same as? MisterGrubbs General Car Audio Discussion & Questions 4 05-01-2012 09:38 PM
How an Odyssey Battery is Made. iamsonic Tutorials & Quick References 27 03-20-2012 08:09 PM
(2)-Odyssey 65-PC1750 Batteries jws84_02 Wiring, Electrical & Other Installation Equipment 29 09-20-2011 04:24 PM
odyssey battery question. davidrforbus General Car Audio Discussion & Questions 12 06-05-2011 11:11 AM
Odyssey Batteries rdminitrucker General Car Audio Discussion & Questions 4 08-15-2010 08:41 AM
