Whats the difference between active and passive? - Car Audio Classifieds!
Old 01-18-2013, 02:45 PM
Austin175's Avatar
0/11 sssss4224
Default Whats the difference between active and passive?
My plan for my front stage is 2-3 6.5s and 1 tweet in each door then 2 tweets in each A pillar.
I'm not sure what the difference between active and passive is or which would be better for me. If you have a amp that has a built EQ do you still need the crossovers hooked up as well?
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 01-18-2013, 03:02 PM
4/11 ssss31258
my brain hurts.
Active means the signal is divided at the RCA level before it gets to the amplifiers
Passive means the signal is divided after the amplifier before it gets to the speakers.
Active is better because it's more concise and because the impedance is not a factor {add as amany or as few speakers as you want.. because the amp will only produce the frequencies it is fed}
[impedance must be within the capability of the amplifier]
Old 01-18-2013, 03:45 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Originally Posted by iamsonic View Post
my brain hurts.
Thank you sir, you answered a question I've been wondering about for a while now...
Sent from my SPH-D700 using Tapatalk 2
comps passive and active?both?help dirtracer27 General Car Audio Discussion & Questions 0 05-17-2011 07:09 PM
passive or active blkmrideon22s (Sundown Audio) 0 07-03-2009 12:54 PM
Active vs passive discussion nismos14 General Car Audio Discussion & Questions 36 12-15-2008 11:23 PM
[BASIC] Active vs. Passive danteBirosel Tutorials & Quick References 0 11-12-2008 01:45 PM
Quick FYI- active vs passive SPL Guru Tutorials & Quick References 11 11-03-2008 08:40 AM
