3k daily and a single batt: Can it work? - Car Audio Classifieds!
Old 01-18-2013, 02:51 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
Default 3k daily and a single batt: Can it work?
I'm planning on picking up a navigator in the next couple of days. the plan is to keep the third row in and run either 4 sa-8s or a pair of sa-12s. I'll have a saz-2k and a 100.4 back there also. the only other acc would be a 15" flip down or 2 pair of headrest monitors.
Is there a single batt that I can run up front that will sustain this system, with the addition of a h.o. alt and the big 3? I was thinking a xs d3100 or similar, but what do you guys think?
Audiopipe Nutthuggery at its finest
Old 01-18-2013, 02:55 PM
0/11 ssssss579
D3100 should handle it.
The Following User Says Thank You to chunt33 For This Useful Post:
8ight (01-18-2013)
Old 01-18-2013, 03:10 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
D3100 is a great batt but its a long ways from the amps.. voltage drop from front to rear might be an issue... can u put a batt in the rear? U can even keep the stock batt under the hood and put the 3100 in the rear.. the shorter the distance between amps and batt the better
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 01-18-2013, 03:13 PM
0/11 ssssss461
A ho alt and D3100 should be fine.
Old 01-18-2013, 03:33 PM
btsteinb's Avatar
0/11 sssss3573
dcpower 370amp alt. any agm that will fit up front bigger the better. that itself might be able to do it.
Old 01-18-2013, 03:35 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
I always recommend having matching batteries. So, if you only use the big one up front, make sure you have twice the required amount wiring that your rear mounted amplifiers need. For example, if your amplifier(s) in the rear of the vehicle require one run of 0g, run 2 0g wires from the front battery (alternator, preferably) to the rear battery.
At least.
Or, run 2 matching small/medium sized batteries front and rear.
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 01-18-2013, 03:38 PM
truebassjunkie777's Avatar
Team Bad Intentions
0/11 ssssss632
I recommend a battery in the rear. Voltage drop is a killer!
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 01-18-2013, 03:45 PM
tacomaguy1's Avatar
0/11 sssss4401
d3100 would work...with a ho alt and those amps I don't see bad voltage drop.
Use high quality ofc and having the battery up front won't matter
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 01-18-2013, 03:58 PM
btsteinb's Avatar
0/11 sssss3573
Just go to sams club and get the biggest duracell agm batt you can fit.
Sent from my PG86100 using Tapatalk 2
Old 01-18-2013, 04:27 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Hey man, if you end up having more space for batts than planned.. I still have batts. Hit me up if you need any
show us your daily single 15" system spl_robb General Car Audio Discussion & Questions 27 06-18-2012 06:16 PM
will this work daily ? constantprojects Enclosure Discussion & Design Construction Help 1 05-15-2012 07:20 PM
interior enclosure work for daily? D810boy General Car Audio Discussion & Questions 9 11-06-2010 02:34 PM
Sub/port up in a trunk: does it work for daily? 1ndatrunk Enclosure Discussion & Design Construction Help 11 08-17-2010 10:04 AM
Can you get ridiculous on a single 8" for a daily? Pillow General Car Audio Discussion & Questions 34 05-22-2010 09:33 PM
