Glue for spider landing - Car Audio Classifieds!
Old 01-18-2013, 08:58 PM
0/11 sssss3842
Default Glue for spider landing
Obviously I kno CA would be best choice but would e6000 or goop be sufficient for the spider landing in a sundown e8 v1?
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 01-18-2013, 09:04 PM
0/11 ssssss822
i learned the hard way just buy the rite stuff the 1st time around and save the headaches. also sand down to bare metal.
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Old 01-18-2013, 09:06 PM
tacomaguy1's Avatar
0/11 sssss4401
e8 isn't very high powered.....might be ok
but on bigger subs I wouldn't
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 01-18-2013, 09:08 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
I would leave goop for the surround.
Current Build:
#60sHereIcome
Old 01-18-2013, 09:13 PM
Big jcc's Avatar
0/11 sssss1178
Feedback Score: 47 reviews
Default ..
^^^^^^^^this an dustcap, if you dont have CA, use 5 min. epoxy
RD D5
RD 15" heavyweight
Old 01-18-2013, 09:23 PM
0/11 sssss3842
This is why i asked. it will see around 200 watts max.
Just didnt want to have to buy a bottle of CA for a little e8. I forget about the 5 min epoxy.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 01-18-2013, 09:49 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
5 min epoxy and amazing goop is all Ive ever used..
Old 01-18-2013, 11:28 PM
0/11 sssss3842
Anyone know if Hobby Lobby carries CA? If not ill just grab some 5-min epoxy from Walmart
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 01-18-2013, 11:45 PM
duff_thrust's Avatar
0/11 ssssss629
E6000 works great.
Sent from my DROID RAZR using Tapatalk 2
Old 01-18-2013, 11:49 PM
0/11 sssss2271
Dont know, but Ive heard some hobbies stores CA glue isnt quite the same as car audio spec CA glue. Could be wrong though..
I would just go with the 5 minute epoxy. I know that will work great. Sand the surface a bit to give the epoxy something to really stick to and you will be good.
spider Problem.. spider wont stay glued down what is better then ca glue damon_dice_hkbang General Car Audio Discussion & Questions 28 06-24-2012 10:19 AM
Aq Recone weekend, glue plastic ring to landing? then spider to that? Magnet General Car Audio Discussion & Questions 2 06-18-2011 09:23 AM
spider landing? Dunbar91 General Car Audio Discussion & Questions 1 10-10-2010 05:00 PM
Tutorial: How to strengthen spider landing glue on SA-8 sundownz (Sundown Audio) 9 05-12-2010 07:12 AM
Spider Landing grimreper912003 (Fix My Speaker) 5 01-19-2010 11:38 PM
