suggest a loud 10" sub for a sealed box - Car Audio Classifieds!
Old 01-18-2013, 11:04 PM
0/11 sssssss19
Default suggest a loud 10" sub for a sealed box
I'm looking for suggestions for a single 10" sub for a sealed box.
I have a 700w rms amp @ 2 ohms that will be powering it.
I will build the box to specs.
Budget is around $250 max
I listen to all genres of music, and am really just looking for the loudest sub while still retaining good SQ.
Please don't suggest a ported box, I'm not interested in one.
Old 01-19-2013, 03:31 AM
0/11 ssssss582
SA10 or Skar vvx10
Old 01-19-2013, 04:11 AM
0/11 sssssss19
Thanks for the suggestion Aaron!
It's funny you suggest the sa 10 because that's actually what I installed and is the reason I'm posting this.
The sa really didn't perform to my expectations in a sealed box. It doesn't get as loud as I thought it would and is pretty picky about what songs it sounds good playing.
I've tried everything and adjusted countless things to no avail so I'm going to try something else.
An ssa gcon was suggested to me, any thoughts on this sub?
Originally Posted by aaronedmonton View Post
SA10 or Skar vvx10
The Following 2 Users Say Thank You to teoulennon For This Useful Post:
sthrnbumpn (01-19-2013)
Old 01-19-2013, 04:53 AM
0/11 ssssss582
Well the problem is you're looking for loud from a sealed. Sealed boxes aren't really supposed to do loud. Just hit hard. I think a gcon would be the same maybe even worse in a sealed box.
Old 01-19-2013, 05:49 AM
Mr.G6's Avatar
0/11 sssss4614
1st off what does "supposed to do loud" and hit hard" mean
last time i checkd it was the same thing..
sealed boxes basically have no rolloff frequency..meaning they will play a wider range of music without being as peaky as a ported box will
sealed box lack in output but more "rounded" playing range..
if you want louder from JUST a single 10 you need to go ported no if's about it.. your not gonna get anything worth bragging about with a single sealed 10.. or do a 4th order
the woofer you already has performs GREAT in sealed boxes and the best choice really.. getting a sub rated for more power aint gonna help either..
sticking with the same cone area and adding say 200 300more watts at best you will NEVER notice the "gain" to the ear.. all itll do is cause further stress on your electrical system
2000 Gmc Sonoma ext cab
Old 01-19-2013, 11:18 AM
0/11 sssssss19
I realize I'm not going to make my car rattle apart with a sealed 10, I've had both sealed and ported boxes and know what to expect.
I just believe there are probably other subs out there that are more suited for a sealed box than the sa 10. Jacob has said himself that 95% of people go ported with that sub and it doesn't seem to be a go-to suggestion when someone asks what sounds good sealed.
Surely one sub can be in the same power range but perform better in a sealed box - whether it be louder or better sq right?
If the sa turns out to be the best I can get for my application after trying something different I'll just chalk it up to a learning experience
Old 01-19-2013, 06:05 PM
0/11 ssssss582
loud to the ears. "hit" is the punch that you feel. theres a difference.
07 Nissan Pathfinder SQ System
JL Audio W3 12 Sealed on Alpine MRP500
Kenwood KFC709PS Components on MB Quart 4.80
not even at 1/50th gain is audiopipe "clean"
Old 01-19-2013, 07:40 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
i had a kicker comp 10 in a sealed probox once, years ago, it sounded great back then
an i never could recreate that particular sound with any of my other sealed/ported boxes since,
im 5x louder, but not as much range
people on the forums will always bash mainstream, but xplodes and comps do great on low power builds
Old 01-19-2013, 07:43 PM
sthrnbumpn's Avatar
0/11 sssss2961
i threw a pair of sa10s in a sealed box also, it lasted a day before i went back to my old setup
super quiet compared to ported, and nothing like the kicker comp from way back
Old 01-19-2013, 07:47 PM
0/11 sssss1417
Fi Q. dont listen to anyone saying that an SA 10 is the way to go as they probably are just posting to post.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Loudest 10" for a sealed box AbuRaz General Car Audio Discussion & Questions 16 08-06-2012 06:59 PM
SD-2 10" Sealed box size? Rylewa (Sundown Audio) 3 01-17-2012 04:51 PM
Loud 12" sub sealed off 1000-1500 watts? ilovebass General Car Audio Discussion & Questions 1 08-18-2011 11:55 PM
Why are silverado's so hard to get loud sealed? oxsign General Car Audio Discussion & Questions 78 04-23-2011 06:49 PM
12" 1.5 sealed box recomendations nismos14 General Car Audio Discussion & Questions 15 07-13-2009 10:06 AM
