weird issue. - Car Audio Classifieds!
Old 01-19-2013, 10:16 PM
0/11 ssssss186
Default weird issue.
i am having a weird issue with my temp setup. when i am parked and just idling my bass slams pretty hard for a single 12, but when i start driving the output cuts in half. as soon as i park again within a matter of a few seconds the output will return to normal. i have no idea what is going on and its driving me nuts. i got a 300 amp singer alt and its only a 1k amp and my voltage doesnt even flinch if im parked or not, so i know that isnt the problem. also some mornings ill get in my vehicle and ill literally have no bass at all.
2003 Jeep Grand Cherokee ltd.
pioneer 80prs
B2 ES6.1I ......................Temp Sub Stage:
B2 zero1, B2 quattro .............B2 Quota
Tantric Sounds HDD 12's ........B2 AS 12
6 Cubes, 33hz. ................4th Order BP 40hz
DLP customs
Guest
0/0 sssssssss
So your voltage drops when you leave correct?
Old 01-19-2013, 10:18 PM
0/11 ssssss186
i have no voltage drop at all. i charge at 14.9 and lowest iv seen it go is 14.7 ever. its the same parked or driving.
pioneer 80prs
Old 01-19-2013, 10:19 PM
DLP customs
Guest
0/0 sssssssss
Sounds like a bad ground. Where are you grounded from? Im thinking either a bad ground when you installed the new alt or a bad ground to your amp. Im leaning toward the alt ground just because when it spools up your losing output.
Old 01-19-2013, 10:26 PM
0/11 ssssss186
the mounting brackets on the alt where ground down to pure steel, it was powdercoated maybe i should have cleaned up the stock mounting brackets?. the amp is grounded to chasis via seatbelt bolt. i know everyone hates seat belt bolt ground but they do go strait to the chasis and i ground them down to bare metal also. figured it would be alright for this little 1k setup.
pioneer 80prs
Old 01-19-2013, 10:28 PM
DLP customs
Guest
0/0 sssssssss
Change your ground to your battery and tell me what happens. For the amp that is.
Old 01-19-2013, 10:33 PM
0/11 ssssss186
dam i dont have enough wire for that, ill have to think of a way to make that work. i got lots of wire for my other setup but if i use that wire for this i will ahve to buy more for my big setup. oh i am also using 2/0 welding cable with 4g reducers.
pioneer 80prs
Old 01-20-2013, 12:37 PM
0/11 ssssss186
so just currious, i havent changed my ground yet. to cold out today. but what would make a bad ground cause such a difference in output between parked and driving?
pioneer 80prs
Old 01-20-2013, 01:57 PM
DLP customs
Guest
0/0 sssssssss
Ground loops do weird things man. Ive seen them do the unexplainable. Bad grounds are probably 90% of the problems that arise in car audio. A good ground is always something you want to have.
Old 01-20-2013, 01:58 PM
DLP customs
Guest
0/0 sssssssss
Gonna see if my brother @taylorfade can chime in here.
Weird RCA issue jeffm4688 General Car Audio Discussion & Questions 5 07-09-2012 12:45 PM
Weird wall cancellation issue RE_XXX General Car Audio Discussion & Questions 7 05-21-2012 07:01 PM
Weird alternator wine issue Bgx88 General Car Audio Discussion & Questions 3 05-01-2011 09:02 PM
Weird voltage issue tommyk90 General Car Audio Discussion & Questions 1 08-17-2010 07:05 PM
Weird RCA issue. jbizzle General Car Audio Discussion & Questions 10 10-17-2009 05:32 PM
