i keep blowing fuses - Car Audio Classifieds!
Old 01-21-2013, 05:11 PM
0/11 ssssss313
Default i keep blowing fuses
i blew my first fuse today its the big fuse that gose on the power wire.. i got a new 1 an as soon as i put it in there was a spark an that one was blown any ideas what it could be? (probably went threw 5 fuses)
Old 01-21-2013, 05:12 PM
Mr.G6's Avatar
0/11 sssss4614
there is either a bare spot in the wire shorting out ( if it blows as soon as hooked up)
or B
fuse is too small and the amp is blowing from trying to pull too much amperage
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
wickedwitt (01-21-2013)
Old 01-21-2013, 05:17 PM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
or B
Either one of these two have a 99.9% chance of being the answer.
Stupid Loud.
Old 01-21-2013, 05:18 PM
0/11 ssssss313
i checked early an there are no bare spots on the wire the fuse is the same size as before (50a)
Old 01-21-2013, 05:21 PM
Mr.G6's Avatar
0/11 sssss4614
did you COMPLETELY take out the wire and visually inspect it that is the only way 2 do it
really thats all it can be
if shit blows upon hookup its got a direct short.. point blank period
if it blows after running the amp for a few mins or whatever.. the fuse is too small.. if the amp is rated for 90amp you need a 90 or 100a fuse
Old 01-21-2013, 05:24 PM
0/11 ssssss313
yeah but maybe i missed something ill check again when theres light outside thanks for the help
Old 01-21-2013, 05:34 PM
0/11 ssssss263
what amp are you running 50amp may not be enough
Old 01-21-2013, 05:36 PM
Mr.G6's Avatar
0/11 sssss4614
says it sparks as soon as hooked up
so that would lead to bare spot in wire and shorting out
Old 01-21-2013, 05:37 PM
0/11 ssssss263
whoops didnt see that
Old 01-21-2013, 05:38 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Unhook wire from amp... insert fuse... if pops... its a short in the wire to the rear... if it doesn't its amp internal short
The Following 2 Users Say Thank You to Jeffhulbert50 For This Useful Post:
8ight (01-22-2013), poopiesmom (01-21-2013)
1000c4 Blowing fuses ? my_stealth21 General Car Audio Discussion & Questions 3 12-07-2012 09:23 PM
sundown saz 1000D blowing fuses blkmrideon22s (db-r) 7 03-22-2012 02:59 PM
Fuses Immediately Blowing E.supra General Car Audio Discussion & Questions 10 02-20-2012 05:29 PM
blowing up a small sub armykyle1 Car Audio Videos 1 09-14-2011 02:27 AM
Square fuses. small fuses w/smartglow SPLpizzaguy Wiring, Electrical & Other Installation Equipment 0 03-15-2011 10:20 AM
