Need some help hooking up a LOC - Car Audio Classifieds!
Old 01-22-2013, 07:55 PM
0/11 sssssss60
Default Need some help hooking up a LOC
Hello everyone! It has been a while since I've posted here. I need some help.
I just purchased a new 2013 Dodge Ram 1500 Laramie Crew Cab with Uconnect 8.4N with Alpine system. It has and 8 inch factory subwoofer in the rear seat.
I plan to make a fiberglass enclosure and add a 10 inch DC lvl 2 sub with a Crossfire XP1400D mono amp. I removed the factory sub and enclosure and used wire taps to connect to the wires that connect to the subwoofer.
What I don't know is which wires to connect the LOC too. I was hoping someone could tell me a way to test which factory wire is pos and neg or does anyone have a 2013 sub wire diagram for this vehicle (doubtful).
Thanks for any help you guys can offer to me.
Old 01-23-2013, 02:07 PM
0/11 sssssss60
Bump. Anybody?
Old 01-23-2013, 02:22 PM
209native's Avatar
0/11 sssss1975
might be a tough one good luck bump
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 01-23-2013, 02:29 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
are all four wires speaker leads?
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 01-23-2013, 02:33 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
U do have the wiring diagram for the LOC correct?
Ur gonna need a 12v constant, 12v switched, and a ground correct? Or is this just for the "speaker wires"?
Use a DMM to find ur 12v constant (truck off and will measure around 12.2v)
Use the dmm to see which wire only gets 12v with the truck started (12v switched/remote turn on)
For the ground i recommend running a whole new ground wire to get rid of any issues or confusion.
If this isnt what u were looking for sorry
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
The Following User Says Thank You to Raptor660 For This Useful Post:
cirrusly_fast (01-23-2013)
Old 01-23-2013, 02:34 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Might have to google search this one...even find a forum based on your truck. Had to do the same with my Tahoe trying to figure out what wire harness with the factory amp where it was located.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-23-2013, 02:38 PM
Raptor660's Avatar
0/11 sssss5243
If the wires pictured (with wire taps on em) are speaker wires going to the factory sub it looks to me to be a factory DVC sub since there is 2 variations of green and white wires.
The wires with the lines on em will be the negatives, and the solid colored wires will be the positives..
Again if thats not whats pictures i apologize, lol
2005 Buick LaCrosse
Old 01-23-2013, 03:08 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
There are 2 plugs that come out of the "alpine" amp (even though it says Chrysler right on it) One is a 22 pin white plug and the other is a 16 pin black plug.
On the 22 pin connector
left to right / top to bottom
pin 1 large black wire with orange stripe (assumed ground for the amp)
pin 2 white with gray stripe (bus input)
pin 3 white with orange stripe (bus input)
pin 4 not used
pin 5 not used
pin 6 green with blue stripe (bus input)
pin 7 green with orange stripe (bus input)
pin 8 gray with blue stripe (bus input)
pin 9 gray with orange stripe (bus input)
pin 10 not used
pin 11 not used
pin 12 not used
pin 13 not used
pin 14 gray with light green stripe (RH dash speaker +)
pin 15 gray with dark green stripe (RH dash speaker -)
pin 16 gray with yellow stripe (LH dash speaker +)
pin 17 gray with no stripe (LH dash speaker -)
pin 18 green with brown stripe (LH headliner speaker -)
pin 19 green with blue stripe (LH headliner speaker +)
pin 20 gray with white stripe (sub -)
pin 21 green with white stripe (sub +)
pin 22 large yellow wire with red stripe (assumed power for the amp)
On the 16 pin connector
pin 1 gray with purple stripe (LH front door -)
pin 2 gray with yellow stripe (LH front door +)
pin 3 green with purple stripe (RH front door -)
pin 4 green with yellow stripe (RH front door +)
pin 5 green with brown stripe (sub +)
pin 6 gray with brown stripe (sub -)
pin 7 gray with dark green stripe (LH rear door +)
pin 8 gray with light green stripe (LH rear door -)
pin 9 green with yellow stripe (RH rear door -)
pin 10 green with gray stripe (RH rear door +)
pin 11 gray with no stripe (center dash speaker, didn't check polarity...I left it stock)
pin 12 gray with orange stripe (center dash speaker, didn't check polarity.. I left it stock)
pin 13 yellow with gray stripe (RH headliner +)
pin 14 green with no stripe (RH headliner -)
pin 15 not used
pin 16 not used
that was off a dodge forum for a 2010 with the rer alpine set up... 4th gen rams are 2009+ so maybe it hasnt changed, hope this helps bud.
TEAM DURTY POWA!!!
The Following User Says Thank You to twizt3dfuc For This Useful Post:
Old 01-23-2013, 06:02 PM
0/11 sssssss60
Thanks everybody. The wires with the taps on them go to the white 4 pin harness on the end. That harness then plugs into the enclosure that houses the sub. I'm guessing they are speaker wires, but I'm not sure. Also all four wires have a stripe on them that's what help create my confusion. Thanks a lot to everyone who posted!
Old 01-26-2013, 08:36 AM
0/11 sssssss60
Ok, I got it hooked up. The wire diagram for the 2013 is almost identical to the one twist3dfuc posted. The power wires are red instead of yellow, and that wire is constant power. I found a power wire to tap into on a different harness and its good to go!
Thanks again everyone!
hooking up amp question stylez12321 General Car Audio Discussion & Questions 7 06-27-2011 01:04 AM
Hooking up DD2515 D2? Ryan1126 General Car Audio Discussion & Questions 12 10-04-2010 08:04 PM
hooking up my ab 400.1 blkmrideon22s General Car Audio Discussion & Questions 5 03-31-2010 09:37 AM
when hooking up highs amp can I....? percy General Car Audio Discussion & Questions 14 03-11-2010 12:17 PM
Hooking up the amp? rumproast789 General Car Audio Discussion & Questions 10 10-15-2009 12:22 AM
