AB 3000XD specs anybody? - Car Audio Classifieds!
Old 01-23-2013, 09:29 AM
Big jcc's Avatar
0/11 sssss1178
Feedback Score: 47 reviews
Default AB 3000XD specs anybody?
Just tring to find specs, if you have owned one let me know what you thought about it...
any info will help.
RD D5
RD 15" heavyweight
Old 01-23-2013, 09:33 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
I've never heard of that amp before...
Sent from my SPH-D700 using Tapatalk 2
Old 01-23-2013, 09:40 AM
Big jcc's Avatar
0/11 sssss1178
Default lol
Lol..right, its an older model, extreme series, an thats all i know about it, oh an it is 2 ohm stable
RD D5
RD 15" heavyweight
Old 01-23-2013, 09:50 AM
Mr.G6's Avatar
0/11 sssss4614
its the american bass xd3000
http://usaci.forumotion.com/t3183-f-s-2-ab-xd3000
click that link for info
From AB website
XD-3000 Amplifier Specifications:
Power Output @ DC 14.4V:
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch.
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm
Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
NOTE the 4k at 1ohm 14v is NOT correct at 16 to 18v itll do 4k
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
Big jcc (01-23-2013)
Old 01-23-2013, 10:17 AM
Big jcc's Avatar
0/11 sssss1178
Default wrong
Hell, i was wrong on the one thibg i thought i knew about it..
RD D5
RD 15" heavyweight
Old 01-23-2013, 10:19 AM
Mr.G6's Avatar
0/11 sssss4614
it happens to us all..
its wierd how if u put 2 letters in the wrong place NOTHING at all comes up lol
Old 01-23-2013, 10:35 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Man, I thought he was lookin for a PB amp, I didn't know AB made amps like that...
Old 01-23-2013, 12:48 PM
hegar817's Avatar
0/11 ssssss928
same amp as the solid audio 2500... I used to have one.
Old 01-23-2013, 01:16 PM
Big jcc's Avatar
0/11 sssss1178
Default all day
what did you think about it?
RD D5
RD 15" heavyweight
Old 01-23-2013, 02:42 PM
0/11 sssss2429
Feedback Score: 46 reviews
I had one, liked it. Rank it with the powerbass xa3000.
looking for ts specs DumBass (DC) 2 06-26-2012 07:55 AM
specs on the new SA-8 V.2 JAYARE2007MAG (Sundown Audio) 2 03-30-2012 09:08 PM
specs burd337 General Car Audio Discussion & Questions 1 12-19-2011 11:56 AM
specs korey_hofer General Car Audio Discussion & Questions 12 12-28-2009 05:46 AM
SA-12 D2 T/S Specs sundownz (Sundown Audio) 2 12-17-2009 01:53 PM
