eminence delta 10 or kappa pro 10 - Car Audio Classifieds!
Old 05-04-2013, 09:41 AM
0/11 ssssss118
Default eminence delta 10 or kappa pro 10
which car speaker to get. im looking for midrange speakers.
the delta is 350rms and the kappa is 500rms. i have a ppi900.4 amp-450x2 bridged at 4 ohms.
Eminence Delta-10A 10" Midrange Driver 8 Ohm 290-412
Eminence Kappa Pro-10A 10" Cast Frame Driver 290-426
Old 05-04-2013, 10:16 AM
Audio Enthusiast
0/11 ssssss733
looking through them both, i personally would choose the kappa pro,
1. it has a copper VC vs the aluminum which will be better applicable for midbass.
2. its a 3" coil vs a 2.5" vc.
3. the fs is much lower, allowing you to get even more bass for your buck.
another good alternative to look into for midbass are these
DIYCable.com : Intro Home Exodus Anarchy
supposedly some of the best on the market if you have room for them.
`"* Toyota Celica *"`
Eclipse Avn 2210p
Diamond audio Hex S600s
U.S. Acoustics USX-600f
Fi rebuilt RE XXX 15 '05 (For sale pm me)
Old 05-04-2013, 10:26 AM
0/11 ssssss118
thanks, but im looking for midrange, not midbass.
Old 05-04-2013, 12:14 PM
0/11 ssssss118
anyone...
Old 05-04-2013, 01:41 PM
Wingman0121's Avatar
0/11 sssss2171
The Delta would be fine unless you are planning on using thousands of watts for your midrange.
Pro Audio Blowout!! (Crescendo, Cadence, Eminence) tez4life Car Audio Packages 19 03-21-2013 08:27 PM
18" Eminence KILOMAX PRO 18A subwoofer woofer driver financethis 18" Subwoofers 0 10-19-2012 12:51 PM
2x 10" Eminence Delta lileddie1127 Component & Coaxial Speakers 11 10-14-2012 07:10 PM
Some of the things going into the Delta DeltaOn4's Off Topic Chat 0 10-04-2010 02:45 PM
Delta-88 alt DeltaOn4's General Car Audio Discussion & Questions 4 08-17-2010 10:25 AM
