1 tweeter a lot louder than the other? 0.o - Car Audio Classifieds!
Old 05-04-2013, 10:00 AM
0/11 sssssss88
Default 1 tweeter a lot louder than the other? 0.o
So I finished hooking up my mb quart pce-213 component set the other day. For some reason 1 of the tweeters is much louder than the other one. I tried switching speaker wires from the louder tweeter, to eliminate possible amp/crossover problem, and there was no difference. The quieter tweeter still sounds good, and gets decent loud at higher volume, and sounds good doing so. I just don't understand why it's so much quieter than the other tweeter. Can anyone explain this? I hope I wasn't sold a partially blown tweeter...sigh
Old 05-04-2013, 10:13 AM
0/11 ssss31255
if you switched the tweeters and the problem stayed with the tweeter, then the problem is the tweeter.
Audio Enthusiast
0/11 ssssss733
get out your dmm and check the impedance of the tweeter. if thats not the culprit, try swapping their locations, depending on the axis (the angle at which it is angled at you) one may be louder if one is on axis and one off. my passenger tweeter "appears" quieter than my driver tweeter because its simply a further distance away, your deck should have a left/right fade option to counteract it. simply adjust in in the direction of the quieter tweeter 1 or 2 clicks.
`"* Toyota Celica *"`
Eclipse Avn 2210p
Diamond audio Hex S600s
U.S. Acoustics USX-600f
Fi rebuilt RE XXX 15 '05 (For sale pm me)
The Following User Says Thank You to Dirtrider4eva For This Useful Post:
OldSchoolFosgate (05-04-2013)
Old 05-04-2013, 10:20 AM
0/11 sssssss88
I will test the impedence the next chance I get. It really is a night and day difference in how loud they are, so I know it's not from axis, or positioning. My only other thought is maybe a wire got pinched somehow mounting them in my pillars. I doubt it, but anything is possible. One of the 5.25 scratches at higher volume also, so Im assuming this guy blew them, then sold them as perfectly working condition. Guess I'll buy new from now on.
Old 05-04-2013, 10:32 AM
Mr.G6's Avatar
0/11 sssss4614
sure on the corssover you aint got 1 set to say 0db tweeter and the other 1 set lower??
bc on the crossover most companies have hookups for diff level of tweeter you want
2000 Gmc Sonoma ext cab
Old 05-04-2013, 10:38 AM
0/11 sssssss88
Well, I tested both tweeters from same channel on amp, and using same crossover, one right after the other. So I am sure it don't have to do with either the amp or crossover. I should have jumped on the bravox component deal when I had the chance. *Facepalm*
Old 05-04-2013, 10:41 AM
0/11 ssssss546
I have a pair of RE XXX tweeters and one was quieter straight out the box
It sounds perfect, just down -3db or so. Not a problem since I run active from my 9887
FYI mine measured identical resistance...
Old 05-04-2013, 10:49 AM
0/11 sssssss88
Car is not here to test. I am guessing its more like a -10db difference. Interesting to know tweeters can sound like that new though...
Old 05-04-2013, 10:54 AM
Mr.G6's Avatar
0/11 sssss4614
ok just making sure
because i had a mb quart comp set and i had the same issue.. but my problem was i was rushing it and had 1 tweeter hooked up to the 0db side and the other was on -5..
just seeing if all options have been explored
Old 05-04-2013, 11:54 AM
0/11 ssssss546
Yeah, was a bit pissed about it TBH but the XXX tweeters sound absolutely AWESOME though so couldn't be bothered sending them back, since I had a ideal fix. I believe mine was a very rare case (with XXX anyway).
I say -3db, it could be more. I will get them out and check later on.
1/0 and 4g lot etznova Wiring, Electrical & Other Installation Equipment 14 05-31-2012 06:33 PM
A WHOLE LOT of 1/0 Gauge jockhater2 Wanting to Buy (WTB) 4 03-06-2012 03:46 AM
fs wiring lot pitbull1078 Wiring, Electrical & Other Installation Equipment 7 05-22-2011 07:49 PM
Lot Of Decals Hellbound Train Miscellaneous Stuff For Sale 34 12-13-2010 12:04 PM
Spy, Terra, People who have a lot of knowledge about a lot of compnaies' productsHELP worstenemy453 General Car Audio Discussion & Questions 55 06-19-2009 10:28 PM
