Alternator noise in speakers - Car Audio Classifieds!
Old 05-04-2013, 02:43 PM
chrisbarrett27's Avatar
0/11 ssssss127
Default Alternator noise in speakers
Hey guys quick question for you. I was messing with the wife's car today. I have a five channel amp pushing a sub and my front speakers. I decided to hook up the rear speakers to the amp today. After doing this I noticed I was getting a pretty bad alternator/whirring noise in the speakers. All I did was run my RCA's from the head unit to the amp and connect the rear speakers directly to the amp since the speakers were so close. I can hear it in the front a little bit but it's way worse in the back. Since I didn't have any issues before doing this I'm assuming the RCA I installed today is jacked up. Is that a safe bet or should I try something else as well? Thanks!
Chris
Old 05-04-2013, 02:47 PM
0/11 ssssss443
You could try some rca noise suppressors.
Old 05-04-2013, 02:57 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Umm.. are your rca's grounded properly. Do you have a Pioneer HU in that car...may have to manual ground out your rcas. Let' see.. are your RCA wires not insulated good and are located near your power wire?
Might have to do this:
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 05-04-2013, 03:18 PM
0/11 ssssss674
Did u run the rca same side as your power? This will cause a whine
Sent from my SGH-T999 using Tapatalk 2
Old 05-04-2013, 07:27 PM
0/11 ssssss127
Damn, that's a crazy ground on that head unit. No it's a kenwood. I tried all different variations of RCA's. My power wire is run by itself on the left side of the car everything else is on the right. It may be something with my head unit (RCA outs front/rear/sub), I'm not sure. If I only use two sets of RCA's it's fine, but as soon as I plug that third set into the unit the noise comes back. I ended up going to radio shack and buying two Y splitters just using the front RCA's so I can patch them to the rear speakers on the amp. It got rid of the whine. I bet if I grounded the RCA's on the back of the head unit like that pic it would probably go away. Thanks for the input fellas.
Chris
Old 05-04-2013, 08:26 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Bad ground?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-04-2013, 08:32 PM
0/11 ssssss522
Also check the amp's ground.
Old 05-04-2013, 10:00 PM
vince79vette's Avatar
0/11 sssss2011
Check ur grounds or add a ground up front off ur engine or battery to the body/frame
Noise through speakers dross93ranger General Car Audio Discussion & Questions 7 11-04-2011 06:12 PM
alternator noise / whine caloriu General Car Audio Discussion & Questions 6 08-30-2011 07:46 AM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
weird noise coming out of speakers... xjoeyc23x General Car Audio Discussion & Questions 7 04-19-2010 12:48 PM
noise from speakers/HU gbo559 General Car Audio Discussion & Questions 16 02-05-2010 01:47 PM
