Need recommendation for 10" Subwoofer + Mini amp. - Car Audio Classifieds!
Old 05-04-2013, 09:46 PM
0/11 sssssss36
Default Need recommendation for 10" Subwoofer + Mini amp.
Hello, I just sold my Sundown SA-8v2 and the Audiopipe APSM-1500. I love Sundown and the audiopipe but it's too powerful, but this is an SUV that has stock 10" subwoofer with max mounting depth of 4.5" I did dynamat the stock panel. I'm looking for something in the 300-400rms range and a small amp that I can hide it under my seat similar to the audiopipe a bit shorter is perfect. Size should be 8"x10"x2.5" or smaller, need to have bass knob. My budget is $250 since this is going to be in the stock panel so it wouldn't handle more power than 400rms.
I do plan to use peel & seal from Lowes for my floors but would need some recommendation on some cheap sound deadening for the doors and vertical location.
It's a 2008 Honda Pilot SE BTW, just got a Alpine KTP-445u installed and a pair of Polk db651 coaxial.
Thanks...
Old 05-04-2013, 09:56 PM
jheist1991's Avatar
0/11 sssss1070
I've used these amps before and they seem to work pretty well, and fits well within your space.
Massive Audio N2 Nano Monoblock 1600W Max Amplifier
Unfortunately, I couldn't find much for subs, but I'd give this one a shot if you can squeeze it, or see if you can find a sundown sd-10 for cheap.
NVX NSW104 10" Dual 4 ohm N-Series Car Subwoofer
As for the sound deadening, peel and seel will work, but not real well. Even the cheap GT Mat from ebay was slightly better, i've used both in the same car.
Old 05-04-2013, 10:58 PM
0/11 sssssss36
Thanks, that looks like a nice sub for $69.99 but I prefer less than 4.5" mounting depth. Will be perfect if it's 4"
As for the amp is a perfect size I need but a bit too over kill for me, I'm looking for a Subwooder DVC D2 for 1ohm configuration and a amp that put about [email protected] stable, going to run 4ga wiring. The cadence 0ga I have is too big for this project.
Also SD-10 D2 mounting depth is 4.75"
Old 05-08-2013, 09:03 AM
0/11 sssssss36
I was planning to get the Sundown SA10D2, but I just found a guy sell a JL 10w1v2-4 for $45 is this a good sub to pair with my Alphine MRV-T420 that put [email protected]? Will the sub handle it fine without any problem distortion etc if I plan to put pure [email protected] at it?
WTB JBL GTO8 OR Alpine Type R 8, Mini DSP, Enough Wire 4 "Big 3," Tweeters, & more 05LGT Wanting to Buy (WTB) 2 05-23-2012 11:04 AM
SUBWOOFER (mini) 3"....pretty tight looking massivespl eBay 5 12-07-2011 12:36 PM
Looking for recommendation for mono bass amp treedawg General Car Audio Discussion & Questions 13 08-18-2011 01:42 PM
Amp Recommendation for 13w7 KRestevan General Car Audio Discussion & Questions 12 03-29-2010 09:07 AM
Box recommendation for 15" RF HX2 golffanatic General Car Audio Discussion & Questions 4 03-03-2010 03:22 PM
