Options on getting more out of subs - Car Audio Classifieds!
Old 05-05-2013, 08:50 PM
0/11 ssssss273
Default Options on getting more out of subs
Any input on what I can do to get more out of my subs or possibly change/add more. I prefer not to spend much if possible.
Right now I have 2 sa12d4 on a skar 2500.1 with a d3400 in rear and mechman 240 under hood. 2/0 welding cable. All this is in a 98 Grand cherokee. Box design is bellow. They sound good, but I wouldlike to get more out of them.
Fb = 33.076 Hz
Vb = 3.546 ft^3
External Height = 16 in
External Width = 37 in
External Depth = 19 in
Port Width = 3 3/4 in
Port Height = 13 3/4 in
I found box design on smd
Grand Cherokee
Mechman 240, Mechman 270, 4 runs 2/0, d3400 under hood, 6 31's agm in rear, 4 silver flute 6.5, 8 vifa 1", 2 sk85.4, 2 zvx 18, 2 sk2500.
Too much electrical is better then not enough.
Suburban build coming soon. Collecting parts.
Old 05-05-2013, 08:53 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Hate to say it, but you've probably got them maxed out. You might get a little here or there with a redesign, but it probably would't be audible.
You need subs that can use the power you have.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 05-05-2013, 08:55 PM
0/11 ssssss273
What do you recommend or should I add another 1 or 2?
Grand Cherokee
Old 05-05-2013, 09:14 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
recone the subs to d2 and wire down to .5
My game is legit,
Old 05-05-2013, 09:19 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
If you've got the room and want to rebuild... for sure. I'd get another pair.
4x world champ
- Floyd E. Toole
Old 05-05-2013, 09:22 PM
Austin175's Avatar
0/11 sssss4224
You got a grand Cherokee like i do an if your cargo is around the same as mine you have roughly around 9cf in the cargo if I remember correctly when I asked t fade about this.
I would say see if you can get a design for 4 12s but first whTs your max dimensions you have to work with.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 05-05-2013, 09:40 PM
0/11 ssssss273
Ill get dimensions tomorrow. I thought I had them on here, but I cant seem to find them. If I got 2 more then my amp would be under powering them. Or would running the amp at roughly .5 make the amp come alive that much more?
Grand Cherokee
Old 05-05-2013, 10:05 PM
Austin175's Avatar
0/11 sssss4224
If you can fit four more then likely subs up port back, an you have the electrical I wouldn't see no problem running that amp under 1ohm cause of box rise you should be good
But we have to start with dimensions before we go any farther.
(caco),
Old 05-06-2013, 12:58 PM
0/11 ssssss273
30 deep
42 wide
32 height
That's all the way to my 3rd brake light.
I was concerned as if the amp can actually push 4 12's
Grand Cherokee
Old 05-06-2013, 01:24 PM
0/11 ssssss614
Sa's perform really well in 4ths wouldnt cost much to build a 4th for the pair and if buildt right should play from 20-55hz with authority. I have 2 sa 10s doing a 44-45 on music in a 3/1 4th with wat u have theres alot of potential. If u decide to go that route and need a sketch up lmk pm me.
2 sundown sa 10z
4:1 4th order
sundown 1500d @.5
02 s10 147.3 (louder now) on the dash
wiring options for 8 subs 98Expo General Car Audio Discussion & Questions 3 08-26-2012 01:05 AM
Wiring options for 6 subs ??? maxdout918 General Car Audio Discussion & Questions 17 03-06-2012 07:17 AM
Building subs..Options? Dunbar91 General Car Audio Discussion & Questions 0 01-25-2012 11:13 PM
What is the wiring options for 6 dual 4 ohm subs? DevinG17 General Car Audio Discussion & Questions 11 04-19-2011 11:47 PM
Sub options Whitymanne General Car Audio Discussion & Questions 12 02-05-2010 10:59 PM
