bandpass amplifiers - Car Audio Classifieds!
Old 05-06-2013, 12:45 PM
0/11 sssssss69
Cool bandpass amplifiers
I would like to step my game up but instead of eqs for days I'd like to know if there are any amplifiers that could band pass from 100 - 10000 hz that sent far too expensive. Even if they can get up to 6-8 I should be fine.
One that I had in mind was the PPI sedona
Old 05-06-2013, 01:09 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Curious as to why you want to band pass that high?
2000 2dr Blazer
The Following User Says Thank You to treylittlefield For This Useful Post:
Novicaine (05-06-2013)
Old 05-06-2013, 03:15 PM
0/11 ssssss674
PPI 900.4 is the only one i can think of that can band pass.
Old 05-06-2013, 04:39 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I can build an active bandpass for that...But why? you using "full-range" speakers?
Old 05-06-2013, 04:47 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
yea soundstream stealth do that
i have 2 for sale as a matter of fact
Old 05-06-2013, 04:54 PM
newarkbeast973's Avatar
0/11 sssss7810
I don't recall any amp band passing that high. I've seen 5khz. Also. It'll help a bit if you describe what equipment you're using and also your goals.
New build coming soon!!
Old 05-06-2013, 05:39 PM
0/11 sssssss69
Basically I'm using midranges that have a response from 120-10000 ... I know the 10000 is really high but ithats where the numbers came from
Old 05-06-2013, 06:08 PM
0/11 sssss5201
What midrange?
2000 2dr Blazer
Old 05-06-2013, 06:39 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
What exactly do bandpass amps do anyway? I seen them built in but as for their function, I'm unsure.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-06-2013, 06:52 PM
jheist1991's Avatar
0/11 sssss1070
As far as I know, it allows you to set a high and low crossover point for the speakers. Basically just tells them to play the frequencies in that range only.
Z V.2 18 Bandpass help 1ndatrunk (Sundown Audio) 12 01-15-2012 05:08 PM
Need help for 6 SA-12 Bandpass Werner D. (Sundown Audio) 18 06-27-2011 10:56 AM
Amplifiers Wes669 Wanting to Buy (WTB) 4 04-21-2011 11:09 AM
Bandpass basshead08 Enclosure Discussion & Design Construction Help 5 03-17-2010 03:09 PM
bandpass? basshead08 General Car Audio Discussion & Questions 16 08-03-2009 02:45 AM
