Fixing bad floor flex - Car Audio Classifieds!
Old 05-07-2013, 02:46 PM
ddbump's Avatar
Loyal Member
0/11 sssss2385
Feedback Score: 17 reviews
Default Fixing bad floor flex
Just deciding if anyone has noticed gains on the meter from fixing floor flex. My floor can literally bounce an AQ sdc motor a few inches high from flexing. I was going to weld 1/4in steel pieces to attempt to brace it. Any input?
1996 dodge ram 1500
-12 Tantric HD 15s
-4 AQ 3500.1s
_TEAM D.O.A_
_TEAM DTF_
Old 05-07-2013, 02:51 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Floor flex huh?! Maybe roof flex but...
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-07-2013, 02:56 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i know some people have used concrete and/or steel to make their floors solid.
My game is legit,
Old 05-07-2013, 02:59 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
Weld steel tubing to the bottom of the car... that seems like itd be the easiest and most effective method
Sent from my SCH-I605 using Tapatalk 2
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 05-07-2013, 03:13 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
Concrete is a sire fire way to fix it. try the second skin spectrum sludge at first. mine has the same issue with the floor. anlong with a bunch of others. My feet flopped around in robins tahoe lol..
Old 05-07-2013, 03:37 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
I second trying something like spectrum sludge first. but if its that bad you likely will need some reinforcement in the form of heavy duty shit
-Youtube Channel
Old 05-07-2013, 03:43 PM
0/11 ssssss546
You know you're doing something right when you get floor flex!
I have heard of people putting concrete on the floor pan, with good results.
Old 05-07-2013, 04:25 PM
tacomaguy1's Avatar
0/11 sssss4401
concrete is cheap too, would think it might have to be pretty thick so it doesn't crack?
Or put some rebar in with it lol
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 05-07-2013, 04:33 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Concrete with layers of wire mesh put in.
More of a factory look might be to weld steel plate on the inside or outside and maybe some tubing welded on the bottom of the floor from under the vehicle. Your carpet would lay pretty flat still if you did it that way rather than a few inches of concrete on the inside of your floor.
Old 05-07-2013, 04:49 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
epoxy
Wall building....contoured floor vs raised floor Wagonized General Car Audio Discussion & Questions 9 02-02-2013 06:04 PM
My Best Flex vid to date! Water on the ground Flex? twistedchild420 Car Audio Videos 0 04-09-2011 07:14 PM
Fixing Spiders gammey4 General Car Audio Discussion & Questions 13 12-28-2010 02:32 PM
