RCA causing Amp to go into protect? - Car Audio Classifieds!
Old 05-07-2013, 07:20 PM
0/11 ssssss697
Default RCA causing Amp to go into protect?
When I have my car on with no rcas in the amp stays off. When I plug one RCA in, the amp turns on and when I plug in the second RCA the amp goes into protect? Anybody ever have a similar problem? Amp is a aq 3500.1 and subs are 2 zcon wired to .7
Old 05-07-2013, 08:16 PM
0/11 sssss2429
Feedback Score: 46 reviews
Does it matter which one you put in first?
Old 05-07-2013, 08:26 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
too much input voltage, if it has input protection
Old 05-07-2013, 09:08 PM
Wingman0121's Avatar
0/11 sssss2171
Hum I wonder if DC is getting into his RCAs somehow or the floating ground is floating it wrong?
Old 05-07-2013, 09:22 PM
0/11 sssss2429
Transformer winding shorted.
Old 05-07-2013, 09:38 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Try a diff set of RCA's.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-07-2013, 10:18 PM
0/11 ssssss697
I was mocking everything up and got a ground wire mixed up and my back battery wasn't grounded to the frame and that us what was causing it. Still weird to me the RCAs is what would cause it to go into protect I didn't think them being plugged in even mattered
Old 05-08-2013, 12:22 AM
0/11 sssss2171
That back battery was probably trying to complete the circuit through the RCAs and through your amp since that's the only negative ground it touches. Good thing it didn't fry your amp's input stage.
Old 05-08-2013, 09:18 AM
0/11 ssss12531
No fuse? Surely a fuse or fuses would have popped. But glad the problem was found. That didn't take long.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Amp RCA Input Causing Noise Burkem_10 General Car Audio Discussion & Questions 15 04-08-2013 12:20 PM
Why is my amp going into protect? Brianyakno General Car Audio Discussion & Questions 10 02-09-2012 01:39 PM
amp protect above 18.5? treylittlefield General Car Audio Discussion & Questions 40 03-09-2011 01:45 PM
Sub Amp Goes into protect mode/Crescendo Amp Blows All Fuses OrenB217 General Car Audio Discussion & Questions 63 09-09-2010 10:50 PM
amp in protect RidnClean General Car Audio Discussion & Questions 11 11-10-2009 04:43 PM
