Two amps one sub? (DVC) anyone do this? - Car Audio Classifieds!
Old 05-07-2013, 10:27 PM
0/11 ssssss378
Default Two amps one sub? (DVC) anyone do this?
Seems like it would be theoretically fine, just curious about if anyone is running something like this? Not strapped though unfortunately.
Old 05-07-2013, 10:28 PM
0/11 ssssss225
U would need to gain match them.
Old 05-07-2013, 10:29 PM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Who not strap or link them so you dont have to worry about anything ?
2005 Toyota Tundra Double Cab
Sub: ---
Speaks: ---
Headunit: ---
Street Stars Motorsports - All Thing Performance/Custom.
Old 05-08-2013, 12:07 AM
0/11 ssssss378
Well I've got an AP-3000d, which is two amps bridged inside so they wouldn't be strappable. But yeah gain match em on the dimm.
Old 05-08-2013, 12:11 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Gain match, easy and no problems.
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 05-08-2013, 12:25 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Curious... what sub are you putting an AP3k to each coil?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 05-08-2013, 12:29 AM
0/11 ssssss378
Well, its an Fi-SP4 18. Buttt I'm pretty sure I'm only seeing 1500-2000 out of the amp after rise and whatnot. When I've got it going full tilt my lights aren't even dimming on stock electrical. Meh I don't know, I might not even bother as the gain in spl is prob not really all that much, probably try and increase the enclosure size first but it was a thought.
916slapin's Avatar
0/11 ssssss825
oscope and gain match them but are decent amps ran several of them over the years, also what imp is the sub and what is the amp wired to now your lights should dim a good amount on a stock electrical
Old 05-08-2013, 12:34 AM
0/11 ssssss378
Yeah I expected it to a bit. Maybe the alternators on 06-mustang gt's (v8) are beefy? Subs dual .7's so about 1.6 on the dimm. Amps rated at 3000 @ 2ohm. I have it set in for 70 volts ~ 2500 watts at max (wanted to avoid clipping). Full tilt the lights dim but its very slight. The sub is def moving though, I'm going to try and measure the voltage drop sometime.
Old 05-08-2013, 12:39 AM
916slapin's Avatar
0/11 ssssss825
something might be wrong I had my stock batt plus a group 31 batt in my bravada when I had it and it dimmed a good amount also you might have crazy box rise so that could be a reason why you have slight dimming only
power dvc MR. YOGI Craigslist Deals 0 06-04-2012 07:09 PM
Two non strappable amps on 3 dvc woofers? 6btdakota General Car Audio Discussion & Questions 4 12-02-2010 09:07 PM
Wmd 18 dvc 4+4 smokinkane 18" Subwoofers 6 10-20-2010 12:23 AM
What does 6 DVC 4ohmers wire to?? Vaginatarian General Car Audio Discussion & Questions 9 05-15-2010 10:17 PM
