How to prep a sub before recone? - Car Audio Classifieds!
Old 05-08-2013, 10:44 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default How to prep a sub before recone?
any tutorials on how to prep a basket / motor before having it reconed? Gonna have a friend do the recone on my sa8's would like to have them ready to go for him, need to know what to, and what not to do.
Old 05-08-2013, 10:58 PM
0/11 sssss2011
Feedback Score: 61 reviews
make sure the gap is free of debris and that your basket is to metal so the glue has something to trap. test fit, test fit, test fit.
Old 05-08-2013, 11:13 PM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
Tons of small things to do some help a ton, others dont help at all.
Get baskets cleaned up, if they are new grind or sand them to bare metal, ca glue can simply take off the surface paint, you want it to bond to the metal instead.
Make sure coil is centered, test fit as many times as you need.
I like to use a 320 sandpaper to the surround lip where it connects to the basket as well a nice paint prep to make sure all oils are off the bonding surfaces. Make sure you have enough clamps as well.
Old 05-09-2013, 11:30 AM
Ryan1126's Avatar
0/11 sssss9178
sorry guys if i wasnt clear enough. But im not doing the actually recone i dont have the tools to do it, but a friend is doing it for fairly cheap so im just cleaning up the baskets for him so they are ready rock for him so he doesnt have to mess with that.
i wanna know stuff like:
What tools will i need? angle grinder? if so what grit paper do i use? should i remove the basket from the motor before doing so to ensure not getting any debris down in the motor? is it okay to use the angle grinder on the spider landing also? is it bad of the paint comes off if i sand too deep?
Old 05-09-2013, 11:35 AM
Mr.G6's Avatar
0/11 sssss4614
angle grinder is MUCH to agressive..
cast baskets are a pretty soft metal..
i use a cordless drill and a wire brush attachment and thats IT..
taking too much material off too fast messes up spider and surround landings
ALWAYS make sure that motor gao is taped up like a mofo before starting anything
and the goal is to get to bare metal ( NO surround/spider material left) BUT not too deep that you gouge the landings
a wire brush on a drill ELIMINATES taking too much material off etc..
and a wire brush attachment costs 4bux at harbor freight
2000 Gmc Sonoma ext cab
Old 05-09-2013, 11:37 AM
Ryan1126's Avatar
0/11 sssss9178
thats what im looking for, so i could use my dremel at a low speed with a wire attachment? I'm affraid of taking off too much at some points thus creating the landings to be uneven in areas. Should i be trying to take the paint off to bare metal?
Old 05-09-2013, 11:38 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
watch a little of this and you will see some of the things you need to do.
How to Recone Subwoofer - YouTube
My game is legit,
Old 05-09-2013, 11:40 AM
Ryan1126's Avatar
0/11 sssss9178
should i just remove the motor entirely? its only 4 bolts, the only thing that scares me is i see a lot of people strip bolts and what not on motors, and then i would be ****ed, it looks pretty much cut and dry to take it apart but is there a trick to putting them back together, is it possible for them to not line up perfect?
Old 05-09-2013, 11:41 AM
Mr.G6's Avatar
0/11 sssss4614
YES dremel is excellnt choice..
all you have to do is get it to bare metal..
nothing more.. when you see a shiny surface your done
Old 05-09-2013, 11:42 AM
Mr.G6's Avatar
0/11 sssss4614
if you can easily remove the motor tyou can go that route too..
Prep for World finals: USACI AMI CUSTOMS General Car Audio Discussion & Questions 49 09-26-2011 11:24 PM
How to prep fibegrlass for paint? Vital Tutorials & Quick References 34 05-17-2011 03:18 PM
deadener metal prep caps Sound Deadening & Fabrication 10 11-16-2010 01:53 AM
How to prep for recone - 13av2 basket Robert_J (Fix My Speaker) 3 07-19-2010 11:06 AM
Sound deadener prep? alvitae General Car Audio Discussion & Questions 12 02-05-2010 08:59 PM
