Aero port question.... What size and how many? - Car Audio Classifieds!
Old 05-09-2013, 01:32 AM
0/11 sssssss35
Default Aero port question.... What size and how many?
I'm going to be running two 10s off of 2500w in a 2.5^3 box at 32hz after sub and port displacement. What would be the best option to go with?
(2) 3" aeros
(2) 4" aeros
(1) 6" aero
Old 05-09-2013, 02:04 AM
hegar817's Avatar
0/11 ssssss928
I think we need a bit more info on box dimension buddy. Especially if you are going to run only 1 aero and you might not have enough depth. Side the subs are and port will be mounted and also the direction they will be facing. Download Torres box calculator and that should answer most of your box building Qs.
Old 05-09-2013, 02:08 AM
0/11 sssssss35
Subs are going under the rear seat of an 08 crew cab sierra. I lifted the seat 3 1/4" and I'm going to try to fire them forward with the ports on the side. If not they will be firing up and the ports will be to the front.
Aero port size for M1 XL 18's telly44444 (DC) 1 05-13-2012 07:15 PM
Aero port size Morals Enclosure Discussion & Design Construction Help 11 04-08-2012 01:23 AM
aero port question littleharv93 General Car Audio Discussion & Questions 14 01-17-2012 05:18 PM
Aero port size for 4 sundown sa8s BassHead143 (Sundown Audio) 26 06-28-2011 10:27 PM
6" PSP Aero Port Cutout size? SacTownBully84 Enclosure Discussion & Design Construction Help 6 07-02-2010 09:26 PM
