using amp without the back cover? - Car Audio Classifieds!
Old 05-09-2013, 06:09 PM
0/11 ssssss358
Default using amp without the back cover?
my ab1100 has an extremely long back cover and makes an awful tinging sound when turned up loud....i pulled the amp to see if the back cover was loose and it is not...but i can use 1 finger and tap the back cover and hear the awful tinging sound that easy,imagine that sound over 34inches of cover..its unacceptable..lol
anyone ran an amp without the rear cover installed?
dodge 1ton dually with 8 12's and 4 vfl 1100.1's....Cummins powered with quad alts and 35 batteries.my build log below. 162.0 at 42hz burp and 160.2 in streetbeat so far ..and is a demo machine!!
Old 05-09-2013, 06:10 PM
hegar817's Avatar
0/11 ssssss928
Better cooling.
Old 05-09-2013, 06:13 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
flexiglass that amp
Old 05-09-2013, 06:38 PM
0/11 ssssss358
got to do something thats for sure.
Old 05-09-2013, 06:48 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Put foam padding (dense not soft like a pillow) onto of the highest points in the amp like this
Old 05-09-2013, 07:28 PM
hawaiianmaxx's Avatar
0/11 ssssss862
add some deadener to the backplate. on the inside as long as it won't touch anything on the board and possibly cause a short, or on the outside if you aren't worried about cosmetics.
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 05-09-2013, 07:58 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7116
Do you have the amp mounted to the box?
Do what Jeffhulbert50 said, except just put the padding on the outside. I'm not sure I would like the idea of putting pressure on the inside of the amp like that.
team graham
Old 05-09-2013, 08:01 PM
Authorized Vendor
0/11 ssss14115
Board is fully supported so there is no worries on that part... he can put foam behind the panel between the amp and mounting board
Old 05-09-2013, 08:03 PM
Beatdown337's Avatar
0/11 sssss1535
Just curious but It would almost seem like adding deadener would cause the amp to run a little warmer than usual?
Old 05-09-2013, 08:08 PM
0/11 ssssss862
I have done it before without any noticeable difference. I'm sure some heat is dissipated through the backplate, but most is definitely dissipated through the heatsink. There might be some vent holes in the backplate, maybe avoid covering those if anything.
PDX amp parts; stacking screws, machine screws, rca plugs, cover screws nismos14 Wiring, Electrical & Other Installation Equipment 1 10-26-2012 07:12 AM
Back up F/S or F/T RE SE & PB XS motors, 2 10" 12 spoke baskets. oxsign Speaker Accessories & Parts 2 07-14-2012 09:24 PM
throw back amp timwebb General Car Audio Discussion & Questions 6 10-14-2011 03:28 PM
rebuilt top end, put distributor back in, suburban wont start. it back fires. kickerfanatic General Automotive Chat 7 09-01-2011 09:21 PM
Got my amp covers back.... BASS_WARRIOR General Car Audio Discussion & Questions 10 01-31-2009 06:18 PM
