Servicing/replacing amplifier cooling fan - Car Audio Classifieds!
Old 05-10-2013, 01:22 AM
chrisbarrett27's Avatar
0/11 ssssss127
Default Servicing/replacing amplifier cooling fan
I recently bought a Zapco 1100.1 amp (older school one/no usb port) and the fan is pretty loud. I have to turn my volume up to at least half if not more to drown it out. I've never owned an amp with a fan before but I'm pretty sure it's not supposed to be this loud. It's mounted on a piece of MDF behind my back seat in a F150. Is there a way to service it to make it quieter or would I just be better off replacing it? Thanks for any help.
Chris
Old 05-10-2013, 01:43 AM
TNJ
0/11 sssss7882
i would contact db-r electronics and ask them how much to replace it. unless youre very good with electrical repairs (soldering, etc). id rather pay someone that has done it before than mess up the cooling elements of my amp.
Old 05-10-2013, 06:08 AM
skinnyg's Avatar
0/11 ssssss828
amps have usb ports now?
Old 05-10-2013, 06:23 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
As long as u replace it with one with a similar power rating u shouldn't have any issues at all... if its 2 wire (red/black) then transfer those wires to the bk/rd on the new fan...if its a 3 wire, its likely temp controlled which means its 2 speed and ull need a similar to replace it
Old 05-10-2013, 09:14 AM
0/11 ssssss127
SkinnyG the newer Zapco reference amps have USB ports so you can plug your computer into them, download s program and tune them up. Pretty cool stuff.
I like to think I'm good at wire repair and
soldering. I'll have to crack her open and take a look. I'll keep you guys posted. Thanks for the help.
Chris
Old 05-10-2013, 09:17 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
sometimes they just need cleaned... my fan axle would pop out causing the blades to scrap the case... i just pinched it back in place
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 05-10-2013, 09:47 AM
Authorized Vendor
0/11 ssss14115
Chris
Its likely a pin connecter so u shouldn't need to solder
Like this one (the white side)
Old 05-10-2013, 10:22 AM
0/11 ssssss127
That would be even more convenient! Thanks!
[SOLD] \stinger cooling fan newarkbeast973 Wiring, Electrical & Other Installation Equipment 4 06-30-2012 08:21 PM
amp cooling fan qeustion. slowpoke General Car Audio Discussion & Questions 16 02-07-2012 09:20 PM
4.95 cooling fan! DonH Hot Deals 1 11-30-2011 06:41 PM
Stinger cooling fan :) AuZy_AuDiO General Car Audio Discussion & Questions 23 07-02-2010 01:11 AM
Cooling fan question?? jfink General Car Audio Discussion & Questions 38 01-31-2009 05:45 AM
