port and sub placement malibu trunk - Car Audio Classifieds!
Old 05-10-2013, 05:59 AM
0/11 ssssss291
Default port and sub placement malibu trunk
I have an 02 malibu wondering if anyone else on here has a trunk setup in one of these cars, If so what have you had the best luck with. Right now i have subs up port to pass. Just looking for suggestions about to build another box
Old 05-10-2013, 06:01 AM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Tried different positions with current box to see what it may gain you? Maybe if you can find your sweet spot you can work off of that?
Old 05-10-2013, 06:13 AM
0/11 ssssss291
well the way the box is now i can either port to pass or to driver side but about to build another enclosure thought about subs an port back or subs up port back. Was hoping someone had the same body style Malibu that could point me in the right direction
Old 05-10-2013, 07:21 AM
0/11 ssssss322
I have a 2013 Malibu. Just built a box for it that is sub firing to the drivers side behind the fender well and port forward. 2 cube box with an 18" (mostly external) port for 31 Hz tuning.
I was mainly going for small and compact. Have not put it on the meter yet but sounds to be close to 140 db with a single 12 and only one 4" aero port.
How big are you looking to go? Do you have 2 12's? What tuning are you looking for?
Old 05-10-2013, 07:45 AM
0/11 ssssss352
These cars get really loud with subs forward, port facing the drivers side of trunk .
Like this:
2 - 12" Custom Sundown Zv3's on saz-2500 - Pure Pressure Concepts - YouTube
Old 05-10-2013, 07:47 AM
Mr.G6's Avatar
0/11 sssss4614
uhh thats like 90% of the trunks out there
2000 Gmc Sonoma ext cab
Old 05-10-2013, 07:53 AM
0/11 ssssss352
Some are louder with everything facing forward, and some are louder with smaller box in trunk at slight angle... his will get loud almost every way, but sub forward/port to side sounded best in that car to me
Old 05-10-2013, 08:00 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
This is a must when I have a trunk
So much cleaner and louder
and kinda fun building it
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 05-10-2013, 08:05 AM
Mr.G6's Avatar
0/11 sssss4614
Like this:
car in that video is a 2 door cavalier..and NO i didnt have to watch the video..
far from the same body style etc..
BUT like i mentioned earlier 90% of trunks sound good with subs front and port to rear side
Old 05-10-2013, 02:59 PM
0/11 ssssss291
It'll be 2 10s re se's and the rear seats will be rarely folded down as I have 2 kids
The New Malibu Setup: (6) Sa-10s and a Warhorse + Trunk Pictures slammedincouch Build Logs 34 05-13-2012 06:20 PM
VVX15" '99 Chevy Malibu trunk build vISUALHype Build Logs 0 04-05-2012 12:35 AM
Sub and port placement in a large trunk?? tez4life General Car Audio Discussion & Questions 5 03-16-2012 10:02 AM
05' Malibu, 145+ Trunk Car. slapuhho Member Rides & System Pictures 34 04-20-2011 02:46 PM
Need help with port placement. themgators511 Enclosure Discussion & Design Construction Help 6 06-23-2010 04:12 AM
