Mechman 240 amp alternator bracket issues - Car Audio Classifieds!
Old 05-10-2013, 11:24 AM
wccfan's Avatar
0/11 ssssss114
Default Mechman 240 amp alternator bracket issues
Hi all,
I recently ordered a 240 amp alternator from mechman and am having trouble getting it to fit on my 2002 Chrysler pt cruiser.
I was told I would need the turbo pt cruiser bracket for an 03 but when my mechanic called the Chrysler dealer for the part they told him the brackets were identical between those two years.
My question is are there any other pt cruiser owners who have done this upgrade? A 240 amp from mechman?? And what bracket did you use or did you just use the stock bracket? I was told it would be direct bolt on which is why I went with the 240 amp instead of the 320 but he's having trouble getting it to fit and says the bottom bracket is about 1-1 1/2 inches too far up to line up with the bolt holes.
Any help is greatly appreciated, Thanks!!
-FULLY DIPPED ANTHRACITE GREY PT
-4 soundqubed HDS300 12's
-Taramps HD3000
-Hifonics zeus 600.4.
-2 g31 batts
-Mechman 240 amp alt
240 Amp DC Power Alternator tdizzle Wiring, Electrical & Other Installation Equipment 22 12-24-2012 07:44 AM
POWERMATER Alternator 240 AMP Gonzo151 Wiring, Electrical & Other Installation Equipment 2 11-05-2012 12:48 AM
Mechman 270 amp alternator tank2215 Wiring, Electrical & Other Installation Equipment 31 12-01-2010 04:54 PM
240 amp MechMan GM alternators (3 available) MECHMAN Wiring, Electrical & Other Installation Equipment 30 08-29-2010 07:31 PM
